I have a device (FM radio, Mp3 player, mini amplifier) that I want to make it portable and power it with 4 18650 lithium batteries. I have a BMS 4S in which I have connected the 4 batteries as usual.
I connected to the BMS the laboratory power supply (0-30VDC, 0-10A) set to 24VDC by inserting a LM2596 module whose output is set to exactly 16.80V. If I increase the current from the power supply, the charging current increases above 2A, resulting in the LM2596 module being destroyed (it can only supply up to 2A).
Can I connect a 24VDC power supply but with a lower current supply (eg 1A or 1.5A) to the BMS by inserting a LM2596 module to have the charging voltage exactly 16,80 VDC to charge the batteries while supplying the device with the required current operation without risk of damage to the batteries or the power supply? It is safely understood without the risk of damaging the batteries or the power supply.
Another suggestion of implementing the construction, with some links if possible, to charge the batteries without being removed from the device?
I searched the internet for information but I'm confused ...
Thanks in advance for any answers or suggestions
PS Sorry about my bad english
