December 22, 2024, 10:23:32 10:23
Author Topic: LTE modems  (Read 3981 times)
zac
-Given: 81
-Receive: 57
« on: July 19, 2019, 11:25:04 23:25 »
I'm working on new product and want to include network connectivity via LTE as an option, but am new to LTE beyond using my cell phone.   We would only be sending GPS coordinates and a small amount of data so want to use a low cost implementation that is reasonably power efficient.  The current plan is to use an STM32 or cypress variant (CY8C/PSoc6) for the microcontroller so prefer an LTE modem that is easy to interface to with having to deal with PCI express.  I would appreciate any suggestions.
https://www.verizonwireless.com/biz/plans/m2m-business-plans/
https://opendevelopment.verizonwireless.com/design-and-build/approved-modules
bobcat1
-Given: 4307
-Receive: 96
« Reply #1 on: July 21, 2019, 07:34:27 07:34 »
Hardware design is straightforward (look at the hardware data sheet from manufacture) but do remember that most LTE modem use different power mostly in the range of 3.8V
For software you will need to implement AT command protocol - you will find lot of code on the net some good some not
You don't have to have permanent IP address for your modem (it cost more) so start wit the lowest cost plan and use lowest bandwidth modem like the CAT-M1 with up to s 400 Kbit
Hope it help
All the best
Bobi
dezso
-Given: 34
-Receive: 137
« Reply #2 on: August 02, 2019, 07:49:09 07:49 »
Check out https://pycom.io/product/gpy/
I have seen used by a friend to make his own remote car starter, works good, he was complaing that he gets 1M data a month ?!? Roll Eyes after a few month he realized that still way more than he use to start/stop/open-close doors.
