December 22, 2024, 01:39:22 01:39
Author Topic: input on idea/project 2x li batteries to usb converter  (Read 3880 times)
sphinx
-Given: 614
-Receive: 271
« on: June 22, 2019, 07:51:17 19:51 »
i would like to make a usb converter with a battery pack of 2x li batteries in parallel and to transform that down to 5v with an output 2-4 amps with charging and protection on batteries like over and low
voltage overcurrent protection. charging and output ports i would prefer separate.
any input on ic's to use. i have looked on some manufacturer and this topic is a bit over my knowledge soft out
when finished i will share scematics and pcb made in altium 19
regards.
and a big thanks to all uploaders
CocaCola
-Given: 170
« Reply #1 on: June 22, 2019, 08:18:59 20:18 »
Not to discourage your plans, but have you looked at over the counter options?  You likely won't get the 4a output (unless you Y adapter two not shared ports) but there are a ton of 18650 USB full-featured battery bank cases out there for cheap...
sphinx
-Given: 614
-Receive: 271
« Reply #2 on: June 22, 2019, 08:29:22 20:29 »
the ones i got have 5 x 18650 batteries in paralell i have looked at some and mmost of those i looked at seems to be batteries in parallel with an output of 3.7volts transformed to 5volts
no worries about discouraging my plans, since it just an idea i got.
and i want to do some playing with altium on rainy days.
sphinx
-Given: 614
-Receive: 271
« Reply #3 on: June 22, 2019, 09:07:13 21:07 »
sadly the post company in sweden has added extra costs to packages on chinese packets so not so cheap to order from china anymore.
i am moving to croatia shortly and i need to find out if it is possible to get cheap stuf from there instead.
looks like croatia has the same as sweden adding extra costs but i need to look how much extra that is since sweden adds 75 sek minimum and the tax on that
« Last Edit: June 22, 2019, 09:10:51 21:10 by sphinx » Logged
-Given: 835
-Receive: 4330
« Reply #4 on: June 22, 2019, 09:53:24 21:53 »
Items from China on ebay has an option to add postage, so it's not sent by China Packet Post.
I don't know if it's all sellers but from Hong Kong I get post in about 4 days. with tracking.
I keep the orders small as they get though without having a tax placed on them.
if its going to get taxed, have it sent via one of the main firms like DHL they only add the tax not a handling fee as well.
some sellers also state the value is higher than what you paid, I have stopped using them.
