Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #75 on: April 10, 2020, 06:59:05 06:59 » |
Request for Ahmed_K:
200 Machine ID: 892270-335554-174001-468578-106704
600 Machine ID: 892270-335554-174001-468578-106704
1200 Machine ID: NonePCI\VEN_15AD&DEV_0405&SUBSYS_040515AD&REV_00\3&61AAA01&0&78
5000 Machine ID: 290576-101313-145475-398769-169576
2001892727-688194-1412113-561756-671273 60038866611-33424082-3396168-1271694-3332316 50001325328-1034161-310109-1883628-1087602 For 1200 you must attach the hardwareID file
norkimo
-Given: 33
-Receive: 71
« Reply #76 on: April 10, 2020, 10:42:45 22:42 » |
200 1892727-688194-1412113-561756-671273
600 38866611-33424082-3396168-1271694-3332316
5000 1325328-1034161-310109-1883628-1087602
Understood. HardwareID file attached.
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #77 on: April 11, 2020, 06:47:36 06:47 » |
License file attached
elavarasan
« Reply #78 on: April 12, 2020, 09:45:20 09:45 » |
Machine ID 600 pixel and 800 pixel 298420-277938-420348-460449-404229
« Last Edit: April 12, 2020, 09:48:14 09:48 by elavarasan »
jzaghal
-Given: 499
-Receive: 55
« Reply #79 on: April 14, 2020, 05:06:02 17:06 » |
Hi Ahmad,
200 Machine ID: 581679-194771-208672-639394-286145
600 Machine ID: 581679-194771-208672-639394-286145
5000 Machine ID: 491240-153057-140945-391297-169576
1200 File enclosed.
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #80 on: April 14, 2020, 07:45:13 19:45 » |
Hi Ahmad,
1200 File enclosed.
2001678390-878163-1311872-423324-1033016 60039089138-33154243-3300057-1933390-3614157 50001517800-792977-304527-2052316-1087602
pushycat
-Given: 213
-Receive: 1448
« Reply #81 on: April 16, 2020, 10:34:57 10:34 » |
For those who have taken licenses and are keen to learn how to work and make designs, and programming, i have included links in the sticky post, related to videos which explain the same. Note: These are not my videos / uploads. Posted on: April 15, 2020, 10:26:39 10:26 - Automerged
found some mistake in 5000 led circuit (see pdf)... mcu works in 5 volt & serial memory working with 3.3 volt ...this is wrong opration.
connect both ic. vcc to 3.3 volt is the right way.
The given schematic is correct and the same is working with many users without any problems. The communication pins of the Flash chip are connected to the Atmega8 but no problems are reported with it. Recently totally different version of 5000V2 software is released which is a single GUI for designing and generating the bin files. The circuit is modified for this version as you have mentioned. Atmega8 and The flash chip works on 3.3V and the 74LS245 which serves dual purpose of buffer and level converter works on 5V. You can modify the hardware as per your choice and monitor its working. Post any problems you see for the information of other members. Posted on: April 16, 2020, 10:19:42 10:19 - Automerged
why 4 flash schematic in 1200 led .. all the memory ics & mega328 are working in 3.3v and 74hc245 connected to 5 volt. i m confused. plz explen
The flash chips works on 3.3V. The Main chip Mega8 or Mega 328 works on 5V. 74LS245 which serves dual purpose of buffer and level converter works on 5V which is then connected to the Pixel LEDs working on 5V. You can connect the main chip to 3.3v as it is capable of working. You can modify when you are working on it. I guess no problems will be faced. As mentioned earlier i am sharing these exclusive projects which are not available for free elsewhere and i am not the designer or owner of the same.
« Last Edit: April 16, 2020, 12:57:05 12:57 by pushycat »
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #82 on: April 16, 2020, 01:56:48 13:56 » |
EN25T80 is not 5V tolerant on its data line, maybe it is working but it will have hardware problem later on. Checking the datasheet of the memory the absolute maximum voltage is 4v
jenifa
-Given: 30
« Reply #83 on: April 17, 2020, 07:29:23 07:29 » |
here is the link for atmega8 fuse bit. Posted on: April 17, 2020, 08:17:00 08:17 - Automerged
I will try to do it. Update:it was very easy to extract correct license info using debugger. Save it to License.lic and it works. Now i'm trying to create a simple exe which extract these data without using any debugger. I am newbie,yes it is very easy to extract correct license using debugger.i alredy extract 600v3 and it is working.
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #84 on: April 17, 2020, 09:51:41 09:51 » |
all above software can not run in windows xp..what can i do ..
Then install newer version of windows
pushycat
-Given: 213
-Receive: 1448
« Reply #85 on: April 18, 2020, 03:09:36 15:09 » |
here is the link for atmega8 fuse bit. If you have a Parallel programmer like the TL866 or the TOP universal programmer, the "49" value on high Fuse is ok. Setting to "49" will disable the reset pin thus the chip cannot be erased further or programmed by a simple programmer like the USBasp. Setting a "C9" on the High fuse and using a 10K resistor on the Reset pin 1 solves this problem. After all the lock bit needs to be set carefully preventing reading of the code.
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #86 on: April 18, 2020, 05:55:54 17:55 » |
I am newbie, witch debugger share plz.
It is a debugger for cracking softwares, use google again
HackAndCrack
-Given: 175
-Receive: 802
« Reply #87 on: April 21, 2020, 12:40:48 12:40 » |
I have neon play software to create pixel led effect. But it is showing only " ? ? ? ? " Marks. But in youtube it is in english versions.
Kindly help.
Because the NeonPlay version that you have is Chinese Language version.
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #88 on: April 21, 2020, 03:05:29 15:05 » |
To all new users, take this as a warning.
Do not send me a personal message asking for license or key. I read all replies and I see all requests, i know who i should answer to his request and who i shouldn't
-Given: 833
-Receive: 4320
« Reply #89 on: April 21, 2020, 03:30:49 15:30 » |
I will mute users asking via PM's This also gees to all PM's in any Topic All Post Must Be In Open There Must Not Be Any Private Shares
« Last Edit: April 22, 2020, 08:38:20 08:38 by pickit2 »
pushycat
-Given: 213
-Receive: 1448
« Reply #90 on: April 21, 2020, 05:51:24 17:51 » |
To all new users, take this as a warning. Next PM i get in this regard will be reported. Do not send me a personal message asking for license or key for any software. All keys are handled by Ahmed_k and his decisions on this regard will be final. How to get English version. Kindly help
Easiest is to get a legal version which is available for just 10K INR. It comes with a USB dongle as security.
HackAndCrack
-Given: 175
-Receive: 802
« Reply #91 on: April 22, 2020, 08:30:46 08:30 » |
To all new users, take this as a warning. Don't PM for licenses.
jenifa
-Given: 30
« Reply #92 on: April 25, 2020, 12:13:45 12:13 » |
here is 600 pixel pcb layout design link
pushycat
-Given: 213
-Receive: 1448
« Reply #93 on: April 25, 2020, 05:59:41 17:59 » |
Thanks for the share. This was an old layout circulated in the whatsapp group long back. In all the circuits used in relation to all the softwares, the author says to disable the RST while programming which i dont recommend personally. This is because the author recommends to use the TL866 Universal programmer which costs about 4000 INR while the same task of programming 9 (Atmega 8 and 328) can be handled by a cheapest available USBasp programmer for just 300 INR. In case of programming the Flash chip, we can comfortably use a dedicated USB flash programmer available abundantly just for 400 INR. Using a 10K resistor at the Pin1 (RST pin) ends all these expensive games. Further an 100E resistor is used in the given PCB for LED indicator which needs to be changed to 1K. Some one can volunteer to draw the PCB and can share the Gerber files for everyone.
jenifa
-Given: 30
« Reply #94 on: April 26, 2020, 07:09:24 07:09 » |
5000v2 have four settings option single controller,manual connection,neutral cut and block connection ,can any one pls explain about neutral cut.
pushycat
-Given: 213
-Receive: 1448
« Reply #95 on: April 26, 2020, 10:37:19 10:37 » |
In the sticky post I have included links to releavant videos. Please have a look where it is explained. Also when you view one video you'll get similar sugession to similar videos on same topics.
madhan7710
-Given: 48
-Receive: 155
« Reply #96 on: April 26, 2020, 12:06:52 12:06 » |
As per pushycat request i have designed a pcb for pixel led v600 and attached the gerber. let me know if i need to upload the design files also...
« Last Edit: April 26, 2020, 05:01:22 17:01 by madhan7710 »
kumar
-Receive: 250
« Reply #97 on: April 26, 2020, 01:59:41 13:59 » |
Pl claryfy the 10k resistor is connected either 5volt supply or ground.
pushycat
-Given: 213
-Receive: 1448
« Reply #98 on: April 26, 2020, 03:46:11 15:46 » |
10K is connected to Pin 1 to +5V which is used for reset pin Posted on: 26 April 2020, 21:01:47 - Automerged
Thanks for the effort. Please incorporate the 10K resistor at pin 1 to Vcc which is the reset. I have mentioned it in my previous post as mandatory for an average user who will program the Atmega with a simple USBasp.
madhan7710
-Given: 48
-Receive: 155
« Reply #99 on: April 26, 2020, 05:12:10 17:12 » |
Added a 1206 resistor in the design and updated the image as well as gerber in my original post...
