You think I am funny guy huh?
December 03, 2024, 04:38:12 16:38
pushycat
600 bulb Pixel LED project with GUI Software
An average person without any knowledge of flash and animation can work stunning designs using this simple and easy to work software interface for pixel LED's like WS2811, 1903, etc. Matrix of any size can be designed with maximum of 600 bulbs. Up to 30 eye catching designs with more than 16 different transition effects can be programmed.  Versions of software included in the project 600v2.1, 600v3, and Newly released 600v4 with 800 bulb design capacity. High resolution schematic included to ease any fault finding and PCB designing
Installation method and licensing:
Once the software is opened, click on "MachineID" found on the extreme right of the top toolbar. A unique ID will be generated. Post the same here in the forum (in plain text and not as attachment) to
get a licence from Ahmad_k moderator. Please do not post Private messages to share the Keygen or Licenses in private.
Once the correct serial number is entered, click "OK" and close the software. Re-open it and see it works as full version. Any version of the software will work with same key provided it runs on same machine on which it is registered. Once you enter the valid serial number, "Licence.lic" file will be found in the main folder. You can copy the same license to the folders of other versions to make it work.
1200 bulb Pixel LED project with GUI Software
After a we had some demands in advance for the 1200 pixel software here is the full package for the Project. Download the full folder and go through the "Read me" file before you start anything. More details about the project and other files are given about what and how. 1200v5 SysInfo.exe is an application to get started. Double click to run this application. and click "Generate" a file named "HardwareID.txt" will be created in the same folder. Post it as an direct attachment (Not a Link) in the project thread with a  request to get a license from Ahmed_k moderator. In return a "license.lic" file will be given by which placing inside the main folder along with the 1200V5. exe will work as full version.
NOTE:  Please put your MachineID in plain text in the request post. There is no need to attach it
200 bulb Pixel Belt project with GUI Software
This software is similar the 600 bulb software but instead of a matrix, this software is cable of designing designs and animation only on a a single thread / belt of Pixel LED's. High resolution schematic included to ease any fault finding and PCB designing
Exactly same as 600bulb software. But you need to get a licence from Ahmed_K Moderator to run it. As previously said, post your Machine ID related to this software in plain text and not as an attachment.
5000 bulb Pixel LED project with GUI Software
Initially me and some of my friends had a strong doubt about this project as it uses only one Atmega8 with a Flash chip and claims about driving 5000 Pixel LEDs. So it took time while i gave the software to some practical users in the lighting decoration field and the software is now practically tested to drive 4000+ leds in real. Two software's can be found in the folder. One is the interface to design any patterns which works without any permissions. The second one is a code generator which imports the Project file generated by the design software and generates a BIN file which is then programmed in the Atmega8 and the Flash chip. You can chose to have any flash chip from 8Mb to 128mb depending on the designs you need. Once you load the project file, click "Generate Bin for the Flash" and then "Generate BIN for the Atmega8" and program both. For getting a license file, post your machineID in the open thread below with a request to Ahmad_k
1800v1.3 Pixel LED GUI Software with 1800 Pixel bulbs Capacity. Uses Single Atmega328 microcontroller. Schematic and PCB exacty same as 600V4.  Just use Atmega328 in place of Atmega8. Licencing same as 1200v5. Generate machine.id and attach link.
5000V2.4 Pixel LED GUI Software with 5000 Pixel Bulbs capacity. Added dimming feature for output. More animations, Single GUI interface, Manual Layout, Accepts SWF, animated GIF and screen capture  functions. Licencing same as 1200v5. Generate machine.id and attach link. Uses Single Atmega8 with Flash chips from 8mb to 128Mb. Single controller and Manual layout functions working. Neutral cut and block connection options yet to be activated by the original author.
For those who have taken licenses and are keen to learn how to work and make designs, and programming, i have included links related to videos which explain the same. Note: These are not my videos / uploads.
Licence Eligibility: Junior members and above levels only. Other requests will be deleted.
« Last Edit: April 28, 2020, 04:19:18 16:19 by pushycat »
Pages: 1 2 [3] 4 5
Author Topic: Pixel LED project with GUI Software  (Read 76959 times)
sadman
-Given: 1832
-Receive: 2899
Sow The Seeds of Love
« Reply #50 on: December 10, 2019, 03:31:22 15:31 »
dear ahmad
here is my machine id for reg code
5000 Pixel Output Generator
Machine ID
 432713-244225-212561-391297-169576
OK
sadman
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #51 on: December 10, 2019, 04:33:10 16:33 »
dear ahmad
Machine ID
OK
sadman
1494089-915057-376143-2052316-1087602
jobitjoseph1
-Receive: 178
« Reply #52 on: December 14, 2019, 07:34:13 07:34 »
Dear Ahmad_k Kindly please provide the serial number for 5000 Pixel Output generator.
machine id : 599933-143201-275225-529253-169576
Thank you
Jobit Joseph
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #53 on: December 14, 2019, 07:00:06 19:00 »
Thank you
Jobit Joseph
1667453-811793-176135-1227576-1087602
-Given: 834
-Receive: 4325
« Reply #54 on: December 15, 2019, 09:29:40 21:29 »
Ahmad_k for 5000 please
machine ID = 433244-143397-213433-552155-169576
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #55 on: December 16, 2019, 01:22:34 13:22 »
1493596-818261-377511-1229958-1087602
6theo4
-Given: 96
-Receive: 41
« Reply #56 on: January 01, 2020, 06:57:06 18:57 »
Happy new year to everyone..
Ahmad_k for 200 and 600 please 481212-163789-208214-750909-370957
and for 1200
/9LJMVY1/CN129633BH001C/PCI\VEN_8086&DEV_0166&SUBSYS_05321028&REV_09\3&11583659&0&10B8A40784090B01098793
thanks
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #57 on: January 02, 2020, 04:51:33 04:51 »
and for 1200
thanks
200
1452965-909645-1312502-311555-931828
600
39568481-33121245-3299503-2045137-3592449
1200v5
license file in the attachment
HackAndCrack
-Given: 175
-Receive: 802
« Reply #58 on: January 05, 2020, 09:13:58 21:13 »
Let me know if anybody needs a license file for 1200PixelV5. I have made a keygen for it and so could send out license files on request.
kumar
-Receive: 257
« Reply #59 on: January 08, 2020, 05:11:20 17:11 »
Dear Mr.Ahmed_K,
here is my machine id for 600 and 200:128640-65812-296979-921772-281514
Hardware id for 1200  v5 :MP197UXCPCI\VEN_1002&DEV_9851&SUBSYS_380817AA&REV_40\3&2411E6FE&1&08            WBY9SYT5
Machine Id code for 5000 output generator:290807-101313-140190-398769-169576
Posted on: January 08, 2020, 12:28:02 00:28 - Automerged
Intresting software.let me know what are the facts influenced in changing the machine id?
pushycat
-Given: 213
-Receive: 1448
« Reply #60 on: January 16, 2020, 09:56:17 09:56 »
Changing the mother board, RAM, Adding external USB drives after license installation, will affect the license file. In short. the hardware devices detected at the time of generating the Machine ID must be always the same to keep the software working.
kumar
-Receive: 257
« Reply #61 on: January 16, 2020, 02:09:25 14:09 »
Awaiting to test in real hardware.thank you
« Last Edit: January 16, 2020, 02:12:29 14:12 by kumar » Logged
jenifa
-Given: 30
« Reply #62 on: January 22, 2020, 02:40:56 02:40 »
respected member   i am trying to make a project with 5000 pixel software,but i face problem when i am trying to add text in
this. software,can any member help me how to add text ,or any one upload the video link about the tutorial of 5000 pixel.thank you
jenifa
-Given: 30
« Reply #63 on: January 27, 2020, 06:59:41 18:59 »
i am new in this forum ,if i request you can i get 1200 v5 license file?
pushycat
-Given: 213
-Receive: 1448
« Reply #64 on: March 03, 2020, 07:11:05 07:11 »
First of all please let me know from where you got the licence for 5000 software. I couldnt see your post regarding that in Sonsivri.
« Last Edit: March 03, 2020, 07:13:09 07:13 by pushycat » Logged
jenifa
-Given: 30
« Reply #65 on: March 03, 2020, 01:45:29 13:45 »
sir ,i am trying it in demo mode,i am unable to generate bin file in output generatotr ,i have no license.
sadman
-Given: 1832
-Receive: 2899
« Reply #66 on: March 04, 2020, 01:34:45 13:34 »
with out license file you cannot generate bin file ask ahmed or hack&crack for license file here in same topic
« Last Edit: March 04, 2020, 01:36:50 13:36 by sadman » Logged
HackAndCrack
-Given: 175
-Receive: 802
« Reply #67 on: March 04, 2020, 08:31:37 20:31 »
My super-duper Universal Keygen is ready but I can't post it here because Ahmed_k and PushyCat don't want me to post it as they had earlier mentioned in this thread that only Ahmed_k will give out the serial numbers and license files.
 Tongue   Tongue   Tongue   Tongue   Tongue
« Last Edit: March 20, 2020, 06:39:25 06:39 by HackAndCrack » Logged
mars01
-Given: 697
-Receive: 1774
« Reply #68 on: March 05, 2020, 12:08:59 00:08 »
I'm not interested in this software but isn't this site primary rule to share and contribute? Why we should do an exception for this?
If you have an interesting piece of software and you are willing to share it, why is not allowed? I would appreciate if someone can explain this ....
koky
-Receive: 157
« Reply #69 on: March 05, 2020, 07:55:55 07:55 »
Dear Mr.Ahmed_K,
Machine Id code for 5000 output generator:474749-159851-175854-534017-169576
thank you
-Given: 834
-Receive: 4325
« Reply #70 on: March 05, 2020, 08:33:45 08:33 »
this is a project by Pushycat. he explained in the topic reasons why it must remain in Sonsivri.
Also he posted  'Next will need a exclusive serial generator / licence generator which will work only for Sonsivri members..'
The important part here is only for Sonsivri members.
If the Keygen is open then that is against the wishes of the original owner of the project.
plus it will go the same way as the Proteus crack, Nemo78 worked on patch, I remember the early days, when it took weeks of work to get a working release, now we can get it working in less time than downloading and installing the software.
We have users in here that not only post our work, they are too ***ing lazy to make their own links, so new links are posted and the next day the same links are in other forums. so users ask for another link, this is for most releases in here.
Note: the way the serial is issued is not the best but it is under control of the original owner of the topic.
Note: "Ahmad_k" is only following the request of topic owner to keep it inside Sonsivri.
« Last Edit: March 06, 2020, 03:12:03 15:12 by pickit2 » Logged
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #71 on: March 05, 2020, 09:59:27 09:59 »
Dear Mr.Ahmed_K,
thank you
1534077-801819-273904-1216092-1087602
pushycat
-Given: 213
-Receive: 1448
« Reply #72 on: March 20, 2020, 06:47:37 06:47 »
Absolutely no problem "HackAndCrack" until you keep helping requesting members with its output. I didnt even expect "Ahmed_K" to post the Keygen in open forum as it is individual hard work but can be used to help Sonsivri members.
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #73 on: April 06, 2020, 07:53:12 07:53 »
Dear Mr.Ahmed_K,
600
39675229-33168644-3538410-1724736-3617702
200
1084057-958356-1287091-107666-1037651
5000
1325559-1034161-303232-1883628-1087602
norkimo
-Given: 33
-Receive: 71
« Reply #74 on: April 09, 2020, 11:33:42 23:33 »
Request for Ahmed_K:
200 Machine ID: 892270-335554-174001-468578-106704
600 Machine ID: 892270-335554-174001-468578-106704
1200 Machine ID: NonePCI\VEN_15AD&DEV_0405&SUBSYS_040515AD&REV_00\3&61AAA01&0&78
5000 Machine ID: 290576-101313-145475-398769-169576
Pages: 1 2 [3] 4 5
