HackAndCrack
-Given: 175
-Receive: 802
« Reply #25 on: May 24, 2019, 05:25:39 17:25 » |
You can download v600 from first post
What about 200 and 1200 versions setup file? Who can provide? Can't be provided in an open forum?
pushycat
-Given: 213
-Receive: 1448
« Reply #26 on: May 25, 2019, 10:01:32 10:01 » |
Provide me 200, 600 and 1200V setup files and keys. Provide setup files and I will send my Hardware ID. I checked link in post #13 and it is not opening for me. I am using VPN but page not opening. What about 200 and 1200 versions setup file? Who can provide? Can't be provided in an open forum?
Post #13 has a link text file which takes you to some videos related to the said software's. Please don't expect all at once. As i have said all software's will be posted one by one in a sequence. As per now we have completed the 600v software, it's working and schematic. You can work and test it for time being and post the results. Request for keys can be posted here. Next will update will have 1200v5 pixel software which is being documented. Once it is completed in a few days will post it for everyone. Nothing will be shared in private. Posted on: 25 May 2019, 07:18:11 - Automerged
Here we go with final and complete package of 600v2, 600v3 and the new and newly released 600v4 softwares. The package is also having a high resolution schematic of the chaser to be used with the software's output. The same link will be available in the sticky once approved by the moderators. All software's are portable and run directly from folder, and thus no installation is found. Once the software is opened, click on "MachineID" found on the extreme right of the top toolbar. A unique ID will be generated. Post the same here in the forum to get a licence from Ahmad_k moderator. Once the correct serial number is entered, click "OK" and close the software. Re-open it and see it works as full version. Any version of the software will work with same key provided it runs on same machine on which it is registered. Once you enter the valid serial number, "Licence.lic" file will be found in the main folder. You can copy the same license to the folders of other versions to make it work. If you feel this project was helpful for you in any way, please click a "Thank you"
« Last Edit: May 26, 2019, 04:40:28 16:40 by pushycat »
pushycat
-Given: 213
-Receive: 1448
« Reply #27 on: May 25, 2019, 02:34:16 14:34 » |
600 bulb Pixel LED project with GUI Software An average person without any knowledge of flash and animation can work stunning designs using this simple and easy to work software interface for pixel LED's like WS2811, 1903, etc. Matrix of any size can be designed with maximum of 600 bulbs. Up to 30 eye catching designs with more than 16 different transition effects can be programmed. Versions of software included in the project 600v2.1, 600v3, and Newly released 600v4 with 800 bulb design capacity. High resolution schematic included to ease any fault finding and PCB designing
Installation method and licensing: Once the software is opened, click on "MachineID" found on the extreme right of the top toolbar. A unique ID will be generated. Post the same here in the forum (in plain text and not as attachment) to get a licence from Ahmad_k moderator. Please do not post Private messages to share the Keygen or Licenses in private. Once the correct serial number is entered, click "OK" and close the software. Re-open it and see it works as full version. Any version of the software will work with same key provided it runs on same machine on which it is registered. Once you enter the valid serial number, "Licence.lic" file will be found in the main folder. You can copy the same license to the folders of other versions to make it work.
1200 bulb Pixel LED project with GUI Software After a we had some demands in advance for the 1200 pixel software here is the full package for the Project. Download the full folder and go through the "Read me" file before you start anything. More details about the project and other files are given about what and how. 1200v5 SysInfo.exe is an application to get started. Double click to run this application. and click "Generate" a file named "HardwareID.txt" will be created in the same folder. Post it as an direct attachment (Not a Link) in the project thread with a request to get a license from Ahmed_k moderator. In return a "license.lic" file will be given by which placing inside the main folder along with the 1200V5. exe will work as full version.
NOTE: Please put your MachineID in plain text in the request post. There is no need to attach it
200 bulb Pixel Belt project with GUI Software This software is similar the 600 bulb software but instead of a matrix, this software is cable of designing designs and animation only on a a single thread / belt of Pixel LED's. High resolution schematic included to ease any fault finding and PCB designing Installation method and licensing: Exactly same as 600bulb software. But you need to get a licence from Ahmed_K Moderator to run it. As previously said, post your Machine ID related to this software in plain text and not as an attachment.
5000 bulb Pixel LED project with GUI Software Initially me and some of my friends had a strong doubt about this project as it uses only one Atmega8 with a Flash chip and claims about driving 5000 Pixel LEDs. So it took time while i gave the software to some practical users in the lighting decoration field and the software is now practically tested to drive 4000+ leds in real. Two software's can be found in the folder. One is the interface to design any patterns which works without any permissions. The second one is a code generator which imports the Project file generated by the design software and generates a BIN file which is then programmed in the Atmega8 and the Flash chip. You can chose to have any flash chip from 8Mb to 128mb depending on the designs you need. Once you load the project file, click "Generate Bin for the Flash" and then "Generate BIN for the Atmega8" and program both. For getting a license file, post your machineID in the open thread below with a request to Ahmad_k
1800v1.3 Pixel LED GUI Software with 1800 Pixel bulbs Capacity. Uses Single Atmega328 microcontroller. Schematic and PCB exacty same as 600V4. Just use Atmega328 in place of Atmega8. Licencing same as 1200v5. Generate machine.id and attach link.
5000V2.4 Pixel LED GUI Software with 5000 Pixel Bulbs capacity. Added dimming feature for output. More animations, Single GUI interface, Manual Layout, Accepts SWF, animated GIF and screen capture functions. Licencing same as 1200v5. Generate machine.id and attach link. Uses Single Atmega8 with Flash chips from 8mb to 128Mb. Single controller and Manual layout functions working. Neutral cut and block connection options yet to be activated by the original author.
For those who have taken licenses and are keen to learn how to work and make designs, and programming, i have included links related to videos which explain the same. Note: These are not my videos / uploads.
Licence Eligibility: Junior members and above levels only. Other requests will be deleted.
« Last Edit: April 28, 2020, 04:19:18 16:19 by pushycat »
sadman
-Given: 1828
-Receive: 2884
Sow The Seeds of Love
« Reply #28 on: May 26, 2019, 05:40:32 05:40 » |
Dear pushycat
first thanks for sharing v4, your post #27 and 28 contain the same link
sadman
Posted on: May 25, 2019, 11:28:53 23:28 - Automerged
Dear Ahmad K
Here is my machine id for unlock code
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #29 on: May 26, 2019, 10:26:25 10:26 » |
Dear Ahmad K Here is my machine id for unlock code
600 pixels version39473198-33059151-3482553-1936680-3630434 Posted on: May 26, 2019, 04:23:48 04:23 - Automerged
pushycat
-Given: 213
-Receive: 1448
« Reply #30 on: May 29, 2019, 03:54:53 15:54 » |
1200v5 Pixel LED software and complete project released. Please follow the sticky for more details. Regards Pushy
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #31 on: May 29, 2019, 06:27:10 18:27 » |
Am i eligible to get the key? Below given is my machine id. Attached HardwareID file also. Thanks in advance.
289228-273780-420142-451625-412055
v60039385617-33501540-3611863-1222085-3486107 v1200 License.Lic Attached
sadman
-Given: 1828
-Receive: 2884
« Reply #32 on: May 30, 2019, 05:18:32 05:18 » |
hi ahmad
here is my machine id for 1200v5
sadman
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #33 on: May 30, 2019, 12:04:49 12:04 » |
hi ahmad
sadman
License attached
sadman
-Given: 1828
-Receive: 2884
« Reply #34 on: May 30, 2019, 02:19:35 14:19 » |
Hi Ahmed
Your LIC file is not working see attach image also i have notice that 1200V5 sysinfo.exe generated the same hardware ID on every PC i also compare the madhan hardware id with mine and both are the same look pushycat by mistake share the manipulated or crack sysinfo.exe that why it is not generating correct hardware id.
sadman
« Last Edit: May 30, 2019, 10:39:30 22:39 by pickit2 »
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #35 on: May 30, 2019, 04:14:59 16:14 » |
Are you sure you sent me the correct HardwareID ? There is no way that sysinfo generate same hardwareId on every machine. Did you get a confirmation that HardwareId.txt is generated when running the tool ? Delete HardwareID.txt and try again
sadman
-Given: 1828
-Receive: 2884
« Reply #36 on: May 30, 2019, 04:27:08 16:27 » |
here is new hardware and it is same as previous one
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #37 on: May 30, 2019, 04:43:13 16:43 » |
Ok problem solved, i obfuscated sysinfo in order to make its size smaller, but it look like the obfuscator is corrupting some data when generating hardwareid
Attached a clean copy of Sysinfo. Please reupload your HardwareID
« Last Edit: May 30, 2019, 04:46:17 16:46 by Ahmad_k »
pushycat
-Given: 213
-Receive: 1448
« Reply #38 on: May 30, 2019, 05:30:03 17:30 » |
Ok problem solved, i obfuscated sysinfo in order to make its size smaller, but it look like the obfuscator is corrupting some data when generating hardwareid Attached a clean copy of Sysinfo. Please reupload your HardwareID
Thanks a lot Ahmad_k. For time being i have removed the Old sysinfo.exe from the project package. Looks like some problems from Mega server as i am not able to download the updated file. Once i download file will update the project package in the sticky.
sadman
-Given: 1828
-Receive: 2884
« Reply #39 on: May 30, 2019, 11:09:23 23:09 » |
Dear pushycat Thanks for the help but your new link in sticky post is not working you used MediaFire sharing service Sadman
« Last Edit: May 30, 2019, 11:11:51 23:11 by sadman »
pushycat
-Given: 213
-Receive: 1448
« Reply #40 on: May 31, 2019, 08:03:17 08:03 » |
In my case it seems working with old file itself. am able to generate bin file in 1200v5. but i have not yet checked in hardware. do i need to regenerate the license or not needed? Madhan Once you are able to generate the bin file, it is proved that the license file is working. But still please note that even without license the "Generate bin file" button is active for 10 seconds before the application closes by itself. Please try to make a small project and verify the working. In case you face the above mentioned problems , get a fresh license file if required. We had problems only with 1200sysinfo.exe file which is replaced by Ahmad_k. It should have no problems with 600v softwares.
Dear pushycat
Sadman
Full package in the Sticky post and links updated and verified to be working. Thanks for your interest in the project.
sadman
-Given: 1828
-Receive: 2884
« Reply #41 on: May 31, 2019, 08:20:21 08:20 » |
hi
here is my new hardware id
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #42 on: May 31, 2019, 12:59:13 12:59 » |
hi
sadman
-Given: 1828
-Receive: 2884
« Reply #43 on: May 31, 2019, 04:19:54 16:19 » |
This time it work fine thanks for the help
pushycat
-Given: 213
-Receive: 1448
« Reply #44 on: June 12, 2019, 02:25:12 14:25 » |
200 Bulb Pixel LED Belt software complete project released. Please follow the sticky for more details. Click the "Thank You" button if you feel it was helpful in anyway. This software is similar to the 600 bulb matrix software, but can design eye catching effects and animations on a single line Pixel LED / Belt of 200 bulbs maximum. Pushy
Full package in the Sticky post. Thanks for your interest in the project.
HackAndCrack
-Given: 175
-Receive: 802
« Reply #45 on: August 29, 2019, 08:32:12 08:32 » |
I request for a license.lic file for 1200V5. Find attached my HardwareID.txt
If the same HardwareID is also good for 200 belt software then send a license for that also.
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #46 on: August 30, 2019, 03:11:09 15:11 » |
License uploaded
dimos
-Given: 62
-Receive: 112
« Reply #47 on: October 06, 2019, 04:36:37 16:36 » |
Dear Ahmad_K,
Here is my MachineID: 589380-229837-308216-585802-260800
Ahmad_k
SCG Moderator
-Given: 173
-Receive: 1298
« Reply #48 on: October 07, 2019, 01:01:37 13:01 » |
Dear Ahmad_K,
60039087513-33070557-3524097-1880486-3179212 2001671773-794445-1284184-476276-549945
pushycat
-Given: 213
-Receive: 1448
« Reply #49 on: December 10, 2019, 01:27:47 13:27 » |
5000 Pixel Project released and available in the sticky post. Initially me and some of my friends had a strong doubt about this project as it uses only one Atmega8 with a Flash chip and claims about driving 5000 Pixel LEDs. So it took time while i gave the software to some practical users in the lighting decoration field and the software is now practically tested to drive 4000+ led's in real. Two software's can be found in the folder. One is the interface to design any patterns which works without any permissions. The second one is a code generator which needs a license file to work. This imports the Project file generated by the design software and generates a BIN file which is then programmed in the Atmega8 and the Flash chip. You can chose to have any flash chip from 8Mb to 128mb depending on the designs you need. Once you load the project file, click "Generate Bin for the Flash" and then "Generate BIN for the Atmega8" and program both. For getting a license file, post your machineID in the open thread below with a request to Ahmad_k
