November 28, 2024, 02:14:50 14:14
Author Topic: XC8 RS232 Eusart Configuration  (Read 5184 times)
intel
-Given: 53
-Receive: 2142
« on: April 21, 2019, 02:46:54 14:46 »
7 Bits Odd 2 Stop Bits on 18F45K22 with XC8 I need to communicate with RS232. MCC does not support it. I couldn't find a sample code in my searches. Do you have a library or code? Thanks.
TucoRamirez
-Given: 257
-Receive: 115
Tuco ... dead or Alive
« Reply #1 on: April 21, 2019, 04:34:24 16:34 »
something like this?
https://github.com/etiq/OpenLab-PIC18F4550-EUSART-examples
intel
-Given: 53
-Receive: 2142
« Reply #2 on: April 21, 2019, 05:24:44 17:24 »
Thanks for your interest TucoRamirez. But these codes are only supported with Hardware.
Your code:
unsigned char config_1 = USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_LOW;
I can't do anything with hardware support. As an example (requirement for me):
1 Start Bit
7 Data Bit
Odd Parity
2 Stop Bit
This CCS C is also very easy. But so far, I've prepared the code with XC8. The different configuration was a surprise for me.
For CCS C:
#users232(baud = 9600, parity = O, xmit = PIN_C6, rcv = PIN_C7, bits = 7, stream = PORT1)
I couldn't do that with the XC8. I'm hoping it could be with an XC8 Uart library.
TucoRamirez
-Given: 257
-Receive: 115
« Reply #3 on: April 21, 2019, 05:50:50 17:50 »
i wonder if the CCS implementation is a software one...
so do you need a soft lib?
you can do 7N2 using 8N1 by shifting and putting manually a stop bit on your send char function
« Last Edit: April 21, 2019, 05:56:56 17:56 by TucoRamirez » Logged
Wilksey
-Given: 161
-Receive: 2549
« Reply #4 on: April 21, 2019, 10:45:23 22:45 »
set the UART to 8 bits and set the most significant bit when sending, this becomes the stop bit and the real stop bit acts as a second one, giving seven data bits and two stop bits
