November 25, 2024, 12:22:02 12:22
Pages: [1] 2  All
Author Topic: SD MMC Card Fat16 Demo in CCS C and Proteus Design File  (Read 60701 times)
fagari
-Receive: 41
« on: November 20, 2007, 10:24:43 22:24 »
Here is my SD MMC Card Fat16 Example project.
It is very good Example for SD MMC Card.
Demo Read CONTURY.TXT in SD CARD and Send RS232 port.
Sorce code and Proteus file  Link:
http://rapidshare.com/files/71131573/SD_MMC.rar
ysy
« Reply #1 on: November 21, 2007, 03:58:47 03:58 »
I dont like ccs, its buggy. microchip produce pic12 pic16 pic18 pic24 pic33, their  c
 compilers are different, features in c18 and c30 and c32 are also different. i think  developers using them are hard to learning these products and tools.
bxac
« Reply #2 on: November 21, 2007, 02:51:10 14:51 »
Proteus has model for MMC. Is this going to work if I want the final design with SD?
aj49m
-Given: 36
-Receive: 41
« Reply #3 on: November 22, 2007, 02:32:14 14:32 »
in theory, mmc and sd are same
endSly
« Reply #4 on: November 25, 2007, 02:04:46 14:04 »
MMC and SD are no identical. SD is a little more fat
incubus22
-Given: 23
« Reply #5 on: November 27, 2007, 04:42:54 04:42 »
Hello fagari!  Smiley
How did you make the image file (COUNTRY.TXT) into a Proteus MMC image (cardimage.mmc)? What program did you use? Please teach me how. Can I convert any text file into this image (cardimage.mmc)?
How about the reverse? I mean, when I want to convert the cardimage.mmc to a text file. Is this possible?
sslobodyan
« Reply #6 on: November 27, 2007, 11:13:32 11:13 »
With WinHex you can read some sectors from your floppy or hard disk. I just save file to clean floppy and save some sectors from floppy to cardimage.mmc. Floppy has FAT16, hard disk FAT32.
incubus22
-Given: 23
« Reply #7 on: November 27, 2007, 01:57:33 13:57 »
Thanks for replying!  Smiley
Can I convert a certain file in my hard disk(for example sample.txt) into cardimage.mmc? How do I do this? There are many convert options in WinHex. Which one should I choose? Please teach me how. It's my first time to use WinHex.
Also, after manipulating the cardimage.mmc in Proteus using a PIC18F(with FAT32 implementation), can I bring it back to the text file format which can be understood by Windows? I am confused with this because I can't understand the data whenever I open cardimage.mmc with Wordpad or Winhex.
fagari
-Receive: 41
« Reply #8 on: November 27, 2007, 02:06:24 14:06 »
Hello incubus22
I use 32 MB SD Card and copy CONTRY.TXT in SD Card.
after make image file with WinHex.
if you don't have sd Card.
You can use 'USB Flash Disk Example' in the Protus 7.2
incubus22
-Given: 23
« Reply #9 on: November 27, 2007, 06:55:49 18:55 »
Hello incubus22
Thank you very much fagari!  Smiley I'll try it.
aj49m
-Given: 36
-Receive: 41
« Reply #10 on: November 27, 2007, 08:27:54 20:27 »
i refered me to protocolo, case SPI
Marineland
-Receive: 124
« Reply #11 on: November 29, 2007, 09:09:05 09:09 »
Hi fagari,
Here's a difference between both SD Image file, I explain:
You file (cardimage.mmc) is a FAT16 and the file (disk.bin) from Proteus sample is a FAT12.
Thus, if i try to use your file (cardimage.mmc) in the simulation, windows don't create a virtual "PROTEUS USB" mass storage... (btw: there's not source to change in FAT16 in Proteus sample directory).
I've not yet find another "Virtual USB Mass Storage" on the web! Sad
If you or anybody have a answer, it's welcom... Smiley
Marineland
fagari
-Receive: 41
« Reply #12 on: November 29, 2007, 06:26:57 18:26 »
Hi Marineland
1. Copy 'cardimage.mmc'(in my project) file to 'Proteus 7 Professional\SAMPLES\VSM for USB\PICDEM FS USB\MSD' directory.
2. Open picdem 'fs usb.dsn' file with Proteus.
3. Right click on the MMC and select 'Edit Properties'.
4. Change Size of Media(MB) to 32 and Card Image File to 'cardimage.mmc' and press Ok.
5. Run simulation and plug usb connector.
6. You must see new removeble drive in my computer.
File read ok. but write and format have problem.
Posted on: November 29, 2007, 07:19:54 19:19 - Automerged
Hi Marineland again
Proteus sample file imformation :
The USB firmware used in this sample is freely available from the Microchip
Technologies website (Application Note  AN1003) and has not been modified.
AN1003 application support FAT16, FAT32 or NTFS file system.
Marineland
-Receive: 124
« Reply #13 on: November 30, 2007, 11:08:12 11:08 »
Hi Fagari,
Thanks for the response...  Smiley
I'v followed yours instructions but the simulation failed:
This's the error: "Can't ceate or open card image file: cardimage.mmc"
What i'm doing wrong?  Huh
Marineland
fagari
-Receive: 41
« Reply #14 on: November 30, 2007, 10:05:56 22:05 »
Hi Marineland,
My MSD Project is here.
http://rapidshare.com/files/73423843/MSD.rar
Try this.
if your problem going on, try reinstall proteus.
Good luck.
Marineland
-Receive: 124
« Reply #15 on: December 01, 2007, 02:27:14 14:27 »
Hi, Fagari,
I've tried your project and It's works fine... Cheesy
Thanks again...
Marineland
mikepic
« Reply #16 on: December 05, 2007, 03:13:04 15:13 »
I'll try your project, because some time ago I tried to make a project with SD card and CCS libraries, but it didn't work at all
kev
-Given: 12
« Reply #17 on: December 23, 2007, 11:29:54 11:29 »
Thanks for the info, I'll try your project as soon as I am allowed to se the links !
xzb
-Given: 16
« Reply #18 on: December 28, 2007, 02:04:13 02:04 »
Thanks fagari! I can pat use !
Trump
« Reply #19 on: December 28, 2007, 08:28:41 20:28 »
Hm.... The driver work, but I have some problem in open files in the root, only the first file open. Files in other folder are OK. And how I close a file?
sevesa
« Reply #20 on: March 14, 2008, 11:24:49 23:24 »
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en532040
Memory Disk Drive File System Library
xzb
-Given: 16
« Reply #21 on: May 13, 2008, 09:13:47 09:13 »
I use this Project proteus OK,but a true  PIC18F252 failing.
why?
   SD 128M
see following data.
**** SD / MMC FAT16  Read Demo for Sonsivri ****
Now Open File on SD Card
cmd0
 cmd=40
 FF 01
 cmd=41
 FF 01 FF FF FF FF FF FF FF FF FF FF FF FF
F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F
cmd1
 cmd=41
 FF 00
 cmd=50
 FF 00
 cmd=51
 FF 00
 read block address=0
 read block tries for FE =2
 sector0=00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 00 00 00 00 00 00 00 00        //proteus display:  sector0=EB 3C 90 4D 53 44 4F 53 35 2E 30 00 02 04 04 00 02 00 02 00 00 F8 F2 00 3F 00 FF 00 61 00 00 00
 cmd=51
 FF 00
 read block addr =32
 cmd=
 FF 00
 read block address=64
 cmd=51
 FF 00
 read block address=96
 cmd=51
 FF 00
 read block address=128
 cmd=51
 FF 00
 read block address=160
 cmd=51
 FF 00
 read block address=192
 cmd=51
 FF 00
 read block address=224
 cmd=51
 FF 00
 read block address=256
 cmd=51
 FF 00
 read block address=288
 cmd=51
 FF 00
 read block address=320
 cmd=51
 FF 00
 read block address=352
cmd0
 cmd=40
 FF 01
 cmd=41
 FF 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
cmd1
 cmd=41
 FF 00
 cmd=50
 FF 00
 cmd=51
 FF 00
 cmd=51
 FF 00
 00 00 00 00 00 00 0
 cmd=51
 FF 00
 cmd=51
 FF 00
 cmd=51
 FF 00
 cmd=51
 FF 00
 cmd=51
 FF 00
 cmd=51
 FF 00
 cmd=51
 FF 00
 cmd=51
 FF 00
 cmd=51
 FF 00
 cmd=51
 FF 00
 cmd=51
 FF 00
 read block address=384
 cmd=51
 FF 00
 read block address=416
 00 00 00 00 00 00 00 03
 cmd=51
 FF 00
 read block address=448
 sector0=02 00 06 07 E0 C9 61 00 00 00 9F C9 03 00 00 00 00 00 00 00 00 00 00 00
 cmd=51
 FF 00
 read block address=480
 00 00 00 00 00 00 55 AA
 cmd=51
 FF 00
 read block address=512
« Last Edit: May 13, 2008, 09:34:22 09:34 by xzb » Logged
fr5cu
« Reply #22 on: May 14, 2008, 02:24:41 14:24 »
can you read an other type of card?
MCan
-Given: 15
-Receive: 119
end of file
« Reply #23 on: June 02, 2008, 04:53:07 04:53 »
when i compile your code, compiler show a message box (i/o error 103)
aquila non captat muscas.
xzb
-Given: 16
« Reply #24 on: June 02, 2008, 07:07:44 07:07 »
hi kireytir
you delete except source .c and .h fiile,afresh the compiler ok!
Pages: [1] 2  All
