-Given: 231
-Receive: 987
« Reply #25 on: April 11, 2020, 01:37:27 13:37 » |
sir i can't understand how to unlock password protected zip file
The name of this forum is sonsivri. Try that
manglam
« Reply #26 on: April 12, 2020, 08:03:24 08:03 » |
zac
-Given: 81
-Receive: 57
« Reply #27 on: April 23, 2020, 02:56:43 02:56 » |
I purchased a few of these power supplies recently and found they were surprisingly good, especially for the price. They also include the unusual capability of limiting power output. The 0-30V 5A version was US$60 and the 10A version was $100 (but 10A version is sold out). I haven't tried the USB software remote control features yet. Model: HM305P/HM310P Output Voltage: 0-30V four digit display Output Current: 0-5A four digit display Power Effect: --Voltage:≤ 0.1%+5mV --Current: ≤ 0.03%+3mA Load Effect: --Voltage:≤ 0.1%+5mV --Current: ≤ 0.01%+10mA Ripple: --Voltage:≤ 20mVrms --Current:≤ 100mArms Display Resolution: --Voltage: 10mV --Current: 1mA https://www.amazon.com/gp/product/B07SPYF8ZW/
sadman
-Given: 1839
-Receive: 2907
Sow The Seeds of Love
« Reply #28 on: August 21, 2021, 01:20:04 13:20 » |
I found on a Russian forum very well optimized design he also added voltage and current regulation through voltage reference based on TL 431 the author of the power supply also publish a article in Russian magazine prakticka elektronika scan copy of article attach a youtuber made this supply and shared his experience link given. https://www.youtube.com/watch?v=M36MDYnTRRw
Renix
« Reply #30 on: November 20, 2021, 03:18:46 15:18 » |
I have built a couple of the RIDEN RD6006 power supply kits using their box and my choice of switching supply to put in the box. They work as advertised for the application I wanted. (Initially as a current controlled supply for anodizing aluminum.) I haven’t actually looked at the ripple output, but I suspect it is mostly determined by the SMPS I selected. The price on BG is ~$67USD, so after a case & SMPS, I’m not sure the cost matches those complete supplies in earlier posts from Amazon. I think I paid a good deal less a year or so ago. The RD6006 is here: https://www.banggood.com/RIDEN-RD6006-or-RD6006-W-Digital-Control-Switch-Adjustable-Power-Supply-DC-Stabilized-Power-Adapter-Buck-Module-Monitoring-Power-Supply-p-1587151.html?rmmds=detail-left-hotproducts&cur_warehouse=USA&ID=6279943One thing I always ask myself before starting a project like this is…. Do I want to design power supplies or do I want to use power supplies? An honest self-answer can save a lot of time. This also applies in many other areas. Some years ago I had a need for a CNC mill to do a paying project. I spent some time evaluating all of the “kit” stuff available for various bare bed mills. In the end I bought a complete mill from Tormach for the job. Paid off the mill with work in < 6 months and never looked back. I’m glad I realized early that I was a user not a builder of mills!
kreutz
-Given: 995
-Receive: 125
« Reply #31 on: April 26, 2022, 06:22:25 18:22 » |
I found on a Russian forum very well optimized design he also added voltage and current regulation through voltage reference based on TL 431 the author of the power supply also publish a article in Russian magazine prakticka elektronika scan copy of article attach a youtuber made this supply and shared his experience link given. https://www.youtube.com/watch?v=M36MDYnTRRw The main problem of this design and derivatives, including similar power supplies with 723 ic, is the negative auxiliary summing voltage ( used to achieve a 0 volts output). The zener diode determines the whole temperature coefficient of the output voltage. An improved option would be to use a low-dropout regulator 3.3volt or 5 Volts IC instead of that zener. Regards, kreutz
« Last Edit: April 26, 2022, 06:28:12 18:28 by kreutz »
-Given: 231
-Receive: 987
« Reply #32 on: April 27, 2022, 07:59:20 07:59 » |
kreutz
During the worst Covid boredom I did make a discrete LM723 type power supply. http://www.sonsivri.to/forum/index.php?topic=68701.msg199426#msg199426However I did not come around to build a working model of it. But the simulation show that I at least was on the correct track (perhaps)
-Given: 554
« Reply #33 on: April 27, 2022, 05:23:57 17:23 » |
I did play with your design and like you say it works well in simulation, The last time I worked on mine I have it all working laid out all the PCB’S got all parts here just need to get back into it and order the PCB’s For it and finish off the software for it. If I get time I may have ago at building and playing around with your design in the link you posted. Need to give myself a kick up the back side and get motivated
kreutz
-Given: 995
-Receive: 125
« Reply #34 on: April 27, 2022, 11:30:05 23:30 » |
-Given: 231
-Receive: 987
« Reply #35 on: April 28, 2022, 04:10:33 16:10 » |
I agree with the author in this video. The idea is kind of correct. But poorly implement. I have built and used many LM723 based adjustable power supplies. The fact that have not been able to go lower than two volt has not bothered me at all.
PM3295
-Given: 360
-Receive: 155
« Reply #36 on: April 28, 2022, 07:07:23 19:07 » |
I am sure this problem can easily be fixed by dropping in a standard voltage (2.5 V) TL431 in place of the zener. Alternatively, using a low-voltage regulator as mentioned. As long as the 431 shunts at least 1 mA, it will regulate very well.
-Given: 231
-Receive: 987
« Reply #37 on: April 28, 2022, 07:43:06 19:43 » |
Not that the LM723 is a bad regulator. But you can find a lot modern linear regulators that can go down to zero volt
PM3295
-Given: 360
-Receive: 155
« Reply #38 on: April 28, 2022, 07:53:16 19:53 » |
In its time, we used the 723 frequently in RF VCO designs because of its very low noise properties, which can help reduce phase and amplitude noise. The noise output of the chip is just a few uV's (100 - 10 kHz BW) with the recommended Cref capacitor. This noise can be reduced even more by using an external PNP pass transistor with the 723. The idea is that the noise of the PNP will be lower than the internal NPN follower.
« Last Edit: April 28, 2022, 08:23:48 20:23 by PM3295 »
Checksum8
-Given: 124
-Receive: 102
« Reply #39 on: April 29, 2022, 05:22:21 17:22 » |
One way to get a zero volt output. Use a ICL7662 or LT1054 negative charge pump to get the negative reference voltage to feed your zener or negative regulator. A ICL7660 would work but does not like more than +10v
-Given: 231
-Receive: 987
« Reply #40 on: April 29, 2022, 07:41:42 19:41 » |
Eh no...with that approach you will ending up injecting high frequency noise into your setup. The high frequency noise will be spawn from the internal oscillator charge pump. What you could do is to use a second low ampere transformer to create a the negative voltage and use a proper low noise voltage reference. For the negative bias. In a hobbyist setup this will be perfectly fine. Or just jeez realize that the LM723 although not a bad regulator ( it make even me feel young). It is outdated if you really need need power supply that need to go below 2 volt. Just use a more modern approach. It is plenty of ICs that can do the job job.
kreutz
-Given: 995
-Receive: 125
« Reply #41 on: May 01, 2022, 03:17:09 15:17 » |
............ Just use a more modern approach. It is plenty of ICs that can do the job job.
Some examples, please.
-Given: 231
-Receive: 987
« Reply #42 on: May 03, 2022, 06:06:47 06:06 » |
Here are some suggestions. You should be able to insert a pass transistor(s) in all of these I think. They do not go down to zero volt except one I think. But They are able to go down to in the range of 0.6 to 0.4 volt. Do you really need to have lower output than that? Non of them are super expensive either https://www.analog.com/en/parametricsearch/11459#/p5576=Output%20Current%20Monitor&p5574=36|45
Manuel
-Given: 687
-Receive: 192
« Reply #43 on: May 03, 2022, 01:09:05 13:09 » |
The one attached can be easily improved providing the right Vin with the right Current and the right heatsink.
Based on 2N3055 or TIP3055 can arrive at 7A and I suggest 35V as VMax.
I suggest to add 10K load on the output.
Just for info: From ST the TIP3055 is easier to be found.
'njoy & take care,
X!
« Last Edit: May 04, 2022, 12:03:35 12:03 by Manuel »
-Given: 231
-Receive: 987
« Reply #44 on: May 03, 2022, 07:36:03 19:36 » |
Dude it is because of the shortcomings of this kind of voltage "regulator" . That they come up with the monolithic, or integrated, linear voltage regulator ICs eons ago.
PM3295
-Given: 360
-Receive: 155
« Reply #45 on: May 04, 2022, 07:01:33 19:01 » |
One way is to use the higher current LM338T and combine it with some op-amps to form a current feedback control loop. The circuit below show one possibility of implementing this idea. The current scaling gives 1V/Amp so the current limit setting can be monitored on TP1 and the instantaneous current feedback on TP2. The scope traces shows the transient response with a 3 Amp current pulse load on the output.
R14 is not needed, but Proteus kept crashing without this in place. Something with the TL431 model.
« Last Edit: May 04, 2022, 08:34:02 20:34 by PM3295 »
-Given: 231
-Receive: 987
« Reply #46 on: May 05, 2022, 12:48:33 12:48 » |
Have you made this in real world or just simulated it. I have only taken a sort look at it. But I have problems with your current sense setup. Mainly that that the voltage on the current sense resistor seems to have lower potential than the LM358 opamp grund point
PM3295
-Given: 360
-Receive: 155
« Reply #47 on: May 05, 2022, 05:00:30 17:00 » |
At this stage, it is just a design suggestion. The latest LM358's have been upgraded from the older design. You may improve the low end more by using the LMV358 (rail-rail), but it only works with 5.5 V rail, so it needs additional 5 V regulator. With differential input configuration using the LM358, it will just limit the low current sensing to about 100 mA. Below that it becomes non-linear with about 70 mV error at zero. Naturally, using a negative supply of a few volts, will correct this error.
The diff amp needs well matched resistors of at least 1% tolerance or better for good performance. Alternatively, one of the feedback resistors should be adjustable.
« Last Edit: May 05, 2022, 05:41:24 17:41 by PM3295 »
PM3295
-Given: 360
-Receive: 155
« Reply #48 on: May 08, 2022, 06:11:15 06:11 » |
As a follow-up for those interested, I tested the current sense, and read-back function using a standard LM358. The circuit actually performed much better than predicted by the simulator, and I could get accurate readings down to as low as 13 mA through the 0.1 ohm sense resistor.
vern
-Receive: 42
« Reply #49 on: May 08, 2022, 10:30:29 10:30 » |
in my opinion there is a flaw in your design: you are measuring the total current with R3, including the currents that are used by the LM358 / LM393 und the current through Q1.
