November 21, 2024, 11:07:20 23:07
Author Topic: LC meter suggestion  (Read 5152 times)
M@X77
-Given: 46
« on: January 22, 2019, 03:35:37 15:35 »
I would like to buy an LC Meter, I like to have these characteristics:
- L start from 1uH and measure also R and Q
- C measure from 1pf to more than 1mF and measure also  ESR
I don't have a lot of money to spend, I evaluated also to do it my self, but I cannot found a valid project and I'm not shure of precision
thanks to everyone that gives a suggestion for a product or a project
Max
sadman
-Given: 1828
-Receive: 2887
Sow The Seeds of Love
« Reply #1 on: January 22, 2019, 03:59:19 15:59 »
commercial L/C meter are very costly what you required here is a project working great and have same feature which you need.
http://www.sonsivri.to/forum/index.php?topic=66141.0
sfiga69
-Given: 199
-Receive: 159
« Reply #2 on: January 22, 2019, 06:09:19 18:09 »
if you try lcr meter M328 in aliexpress or ebay, you are something less than $ 7
motox
-Given: 257
-Receive: 322
« Reply #3 on: January 23, 2019, 01:58:51 13:58 »
Last November I searched for the best option to buy, more precisely the model with the best price-quality ratio.
So I bought the LCR Meter DE-5000 from DER EE.
I like it very much and recommend this one.
The cheapest I could find was on eBay for 89€ with free shipping. I had to pay around 33€ of customs.
I don't know if this is too expensive for you, but for sure it's worth each penny.
Search for "DER EE High Accuracy Handheld LCR Meter DE-5000 bundle TL-21 /TL-22", vendor: sacchan2008
You can easily make the optical USB interface if you need one.
Some specs:
  • C resolution: 0.01pF
  • C  max: 20 mF
  • L resolution: 1 nH
  • L max: 2 kH
  • R resolution: 1 mOhm
  • R max: 200 MOhm
  • Freq. max: 100 kHz
  • 4-wire measurement
M@X77
-Given: 46
« Reply #4 on: January 23, 2019, 07:52:04 19:52 »
Thanks!
Sandman the project is interesting, but not complete, I would like also measure Q, it's very similar to the M328 proposed from sfiga69, at this point it's to easy buy one to few euro
The LCR meter suggested by Motox is very interesting, quite cheap, and has all functionality, on italian ebay.it is not sold, but I found it on ebay.com
dR-mR
-Given: 59
-Receive: 106
« Reply #5 on: January 23, 2019, 08:22:04 20:22 »
If you are interested in diy lc meters look at this site:
http://kripton2035.free.fr/index.html
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #6 on: January 23, 2019, 11:34:20 23:34 »
check this one :
https://www.aliexpress.com/item/2016-New-TFT-LCD-M328-Transistor-Tester-LCR-Diode-Capacitance-ESR-voltage-meter-PWM-Square-wave/32645287865.html
its 2018 new version V1.13 can test the DS18B20 and DHT11 and  IR_decoder
for same price more function  Wink
« Last Edit: January 23, 2019, 11:38:45 23:38 by zokij » Logged
motox
-Given: 257
-Receive: 322
« Reply #7 on: January 24, 2019, 10:12:39 10:12 »
I wouldn't say "for the same price", as the new one costs 14.1€ and the old model (I have one) is available starting from 6.1€, e.g.:
https://www.aliexpress.com/item/LCD-Digital-Transistor-Tester-Meter-Backlight-Diode-Triode-Capacitance-ESR-Meter-MOS-PNP-NPN-L-C/32943597188.html
I classify this type of meters as "nice toy to have around because they are so cheap".
I don't even trust my Brymen Multimeter BM869S (209€) to measure capacitors. I've seen bad capacitors that looked OK on the Brymen, as is only measures capacitance (no other parameters).
« Last Edit: January 25, 2019, 07:49:55 19:49 by motox » Logged
bobcat1
-Given: 4273
-Receive: 94
« Reply #8 on: January 27, 2019, 08:39:02 08:39 »
Good LCR meter is depend of your need - whether you design RF circuit it is not even close to good or accurate.
Most of LC meter of DIY staff is with the same principal of using a comparator as an oscillator and measuring the frequency it produce with the microcontroller for a DIY it is very good and easy to build.
For a good professional  product you need to use a 4 wire tester mostly very expensive product but some can be found 2nd hand on EBAY for reasonable price for whom who can afford it.
All the best
Bobi
M@X77
-Given: 46
« Reply #9 on: January 28, 2019, 10:39:05 10:39 »
LCR Meter DE-5000 suggested by Motox seems a best solution between the DIY and high level instrumentation
I'm looking for it
