December 22, 2024, 02:06:05 02:06
Author Topic: Class AB Audio Amplifier for Small Signals  (Read 9824 times)
especialista
-Given: 84
-Receive: 161
« on: December 29, 2018, 05:19:06 17:19 »
This is a simple amplifier for those ol' fashioned way PCB audio pickers, did by me in the past.
RV1 - Adjusts input signal
RV2 - Ajusts clipping between Q1 and Q2
(First post, sorry if I did any mistake!)
« Last Edit: January 01, 2019, 04:31:45 16:31 by especialista » Logged
PM3295
-Given: 360
-Receive: 155
« Reply #1 on: December 31, 2018, 02:43:30 14:43 »
If you use global feedback instead of local feedback, you should be able to get rid of the large electrolytics, improve LF response and reduce the THD% figure by a factor of about 20.
« Last Edit: December 31, 2018, 03:23:59 15:23 by PM3295 » Logged
« Reply #2 on: December 31, 2018, 05:41:31 17:41 »
what's the output power? Can we increase it and keep the profile as above?
especialista
-Given: 84
-Receive: 161
« Reply #3 on: December 31, 2018, 08:59:23 20:59 »
Never measured, but I'd tell something around 3/4[W] at maximum.
It was not designed for "rock'n'roll". Just to amplify small signals to a small acoustic box.
PM3295
-Given: 360
-Receive: 155
« Reply #4 on: January 07, 2019, 06:14:14 18:14 »
With a few more simple modifications, it should perform very well. Together with the higher supply voltages, it could produce about 20 W into a 4 ohm speaker load at a low THD near 0.004%. As shown all harmonics of the 1 kHz input tone is down almost 90 dB. Bear in mind that the original design without global feedback may have produced over 3% THD at full power. For good thermal stability, the diode should be mounted close to the heat-sink.
Make sure you set P1(multi-turn) for an idling current between 10-20 mA flowing in the main output transistors once the amplifier has warmed up.
Posted on: January 01, 2019, 12:33:38 12:33 - Automerged
Distortion and noise can be further cleaned up by using a better low noise opamp like the LT1028. It shows nearly a 4 times reduction in the THD going from the LF351 to a LT1028.
Faros
-Given: 141
-Receive: 178
« Reply #5 on: January 10, 2019, 10:13:05 10:13 »
@PM3295
which software is used for those analyses ?
dennis78
-Given: 272
-Receive: 154
« Reply #6 on: January 10, 2019, 01:41:53 13:41 »
I think this is TinaTI software
PM3295
-Given: 360
-Receive: 155
« Reply #7 on: January 10, 2019, 08:47:34 20:47 »
That is correct, although some of the features are only available on the full registered industrial version.
mr_byte31
-Given: 75
-Receive: 144
« Reply #8 on: January 16, 2019, 09:17:17 09:17 »
I think it is better to avoid using opamp ( specially LM741) , they have bad frequency response.
I used one before and it made the sound quality very bad.
Posted on: January 16, 2019, 04:14:42 04:14 - Automerged
I also remember that you need to add a small resistance (5 Ohm) on the common of Q3 and Q4 to avoid mismatch !
at least that what I remember since long time ago.
especialista
-Given: 84
-Receive: 161
« Reply #9 on: January 16, 2019, 08:52:44 20:52 »
You're absolutely right.
That's why I've choosed High Speed JFET LF351 for this amplifier.
You should try one of these: They are amazing for pre-amp.
PICker
-Given: 207
-Receive: 110
« Reply #10 on: January 17, 2019, 07:12:06 07:12 »
I agree, the JFET input OPA does the difference.
There are new designs for reducing distortion and noise and increasing precision like the TI OPA3234 SoundPlus.
« Reply #11 on: January 18, 2019, 02:22:43 02:22 »
I agree, those OPAs sound much better than 741 and NE5532..
