PIC18F2550 microcontroller communicates with 24LC512 EEPROM and DS1631 temperature sensor over an I2C bus.
24LC512 The first four bits of the 7-bit address for this device is set as 1010. The next three bits are,however, configurable through its A0, A1, and A2 pins. For example,a 24LC512 device with A0 at logic high and A1-A2 pins grounded willhave its 7-bit address as 1010001 . This scheme allows a maximumof 8 similar devices addressable on the same I2C bus.
( from Inter-Integrated Circuit (I2C) communication - Embedded Lab)
don't you think just posting one page of a pdf file, and this post is adding anything to a site that has a good reputation for having intelligent content. you only have to look at image to see two errors that were in the post I deleted.
http://www.sonsivri.to/forum/index.php?topic=52924.msg178100#msg178100 this was another of your silly posts.
