December 22, 2024, 06:01:55 06:01
Author Topic: PIC18F2550 development board  (Read 5656 times)
gevv
-Receive: 534
« on: September 27, 2018, 08:21:05 20:21 »
PIC18F2550 development board. Compatible with Arduino shields and arduino uno boxes. (Arduino uno with the same size port in the same sequence.) eagle cad pcb, schematic, bootloader, code etc all files It is shared open source project
PIC18F2550 DIP prosessor and up to 48 MHz prosessor speed, 32 kb memory, Sram 2048 byte, eprom 256 byte.
 External 24C02 EEPROM on the circuit (2048 bit, 256 byte memory)
 10 each 10 bit ADC input.
 2 each PWM input.
 Total 19 Each I/O
 Ports per Array USB, UART serial, Spi, I2C, CAN
 Programming port: External programming option with USB without programmer or Standard ICSP. (Such as Brenner, pickit2, pickit3, k149)
 Prosessor and eeprom 3.3 VDC or 5 VDC with the option to run with 3.3 volt modules to connect, sensor for voltage level circuit doesn't needs.
 The jumper and hid and cdc connection options in your usb applications.
 Option to program, prototype 28-pin processors such as PIC18F252, PIC16F876 with integrated socket on the circuit.
 It is open source, it can be repaired by maker, it can be produced for educational purposes. Pickat is a registered trademark, can be done with commercial registration.
 7 to 12 volts DC supply voltage can be supplied by adapters Our recommendation is the 7.5 volt high quality adapter that is most common in the market.
 3.3 volt 5 volt regulators for accessories to be installed.
 It has 500mA fuse for USB protection. Fuse can be changed.
 When you use the adapter, it does not use the USB feed.
 The blue warning LED illuminates when the system supply is set to 5 volts.
 Selection of pins with 3 jumper.
 Reset and bootloader buttons.
 Test codes for 2 blink led. PortC 0 and PortC 1
 Compatible with Arduino shields and arduino uno boxes. (Arduino uno with the same size port in the same sequence.)
 With all pic compilers, you can upload the pic18f2550 hex code to pickat via USB without programming.(proton basic, pic basic Pro, xc8, CCS c, micro pascal, microc such as)
 Pickat is designed with 20MHz crystal. But if you want 10MHz, 8 MHz Crystals can be inserted with the iron. SMD crystal is used to remove easily.
 DIP processor is used, you can remove it from the socket and insert the new one in case of malfunction in the processor.
https://www.pickat.org/
Umarım gelmez ilham perilerimin sonu... ! Modifiye uzmanı web üzerinde 320volt.com ile yaktı mumu....
