December 22, 2024, 05:59:49 05:59
Author Topic: Zhongdi ZD-987 help wanted to repair  (Read 8057 times)
mitsos
-Given: 3101
-Receive: 4641
« on: August 27, 2018, 09:41:12 21:41 »
hi
I use the last years this cheap station and suddenly the desoldering part is no more working.
After power on, every second, all segments of LCD are tuning on and a beep is sounding for a moment.
The desoldering gun is no heating.
I reverse engineering the microcontoller pcb, ZD-LTY-2, it uses the C8051F310.
The soldering part is working OK. Is there a way to read the contents of C8051F310?
mitsos
« Last Edit: August 30, 2018, 04:00:18 16:00 by mitsos » Logged
h0nk
-Given: 227
« Reply #1 on: August 27, 2018, 10:21:16 22:21 »
Hello mitsos,
there is a C2 interface for 51er Silicon Labs Controller.
Look for Silicon Labs Applikation Note AN127.
I bought a cheap clone of the JTAG/ISP-Adapter on Ebay.
It works well.
But i am afraid that the security options are set and
Flash Read-Out is prohibited.
Good Luck, and
Best Regards
fpgaguy
-Receive: 166
« Reply #2 on: August 28, 2018, 06:36:31 18:36 »
there's a couple teardowns of this device with suggestions to improve
usually this is a heating element or pump problem and not the micro
-Given: 835
-Receive: 4330
« Reply #3 on: August 29, 2018, 10:54:17 10:54 »
This maybe a starting point.
https://www.eevblog.com/forum/chat/firmware-for-zd915-solder-station-converter-in-hex/msg1221804/#msg1221804
bigtoy
-Given: 340
-Receive: 297
« Reply #4 on: August 29, 2018, 03:46:36 15:46 »
I had problems with my cheap Chinese hot-air desoldering system. I took the handle apart. Turned out there was a thermal fuse up close to the heating element in the handle. And it had done what thermal fuses often do - it went open-circuit. I just bypassed it and the unit started working again.
mitsos
-Given: 3101
-Receive: 4641
« Reply #5 on: August 30, 2018, 03:58:25 15:58 »
hi
I upload a small video to see the fault here:
https://we.tl/t-D10ME6I8s1
you'll see after power-on that in every flashing displays for a moment the working temperature 440°C and then go to faulty operation forever, either the gun is connected or not.
I attach the power PCB. When I force 3V through a 300ohm resistor to optocoupler pin 1, the gun is starting to heat.
I ask also the Zhongdi for this fault.
mitsos
« Last Edit: September 01, 2018, 08:07:49 08:07 by mitsos » Logged
-Given: 835
-Receive: 4330
« Reply #6 on: August 30, 2018, 06:05:19 18:05 »
Both controller pcbs are the same. only the code is different.
the unsoldering gun has an extra pin for the trigger, your heater seams to work.
how about the thermistor.
I looked if the workshop stores to see if they had any scraped zd915's
but they have been moved, the store keeper is away on holiday for another two weeks.
mitsos
-Given: 3101
-Receive: 4641
« Reply #7 on: August 30, 2018, 07:21:26 19:21 »
hi
I forget to write some notes:
the resistor of 120k, at the feedback of 358, is present only on the desoldering control PCB
the value of VRA1 comes from measurement
I take measurements on thermocouple from the soldering part, I find about 74microvolt/°C and the gain of 358 is about 65. With Vref=2.5V you get a maximum temperature 520°C.
The gun has a smart sensor of "busy" station,the SW-18010P from SUR (on net you find the same from SOYO), it is a spring that has at its centre a piece of wire. The spring action is like an inverted pendulum and as it vibrates, during working with the gun, it touches the wire. It is a simple switch that put the pin P1.4, through a resistor RA1 with value 1kohm (not appeared in my schematics), to earth. If for 15 minutes the spring is not touch the wire, the C8051 set the temperature to 200°C.
The small fan (not appeared in my schematics) gets its supply with half rectification like D2 and E1 in the control PCB schematic.
mitsos
« Last Edit: September 01, 2018, 04:59:07 16:59 by mitsos » Logged
