December 22, 2024, 10:46:02 10:46
Author Topic: Cable for PICkit  (Read 5189 times)
Signal
-Given: 113
-Receive: 81
« on: July 31, 2018, 08:41:19 20:41 »
I like to make little things by hand. It eats my time but adds a (childish) joy. I use a slightest opportunity to make even unpractical things if they inspire me. Sometimes I motivated to test an idea, sometimes I expect a nice look or just want to try a tool that did not try before.
At this time there was a coincidence: I needed a new ICSP cable between PICkit4 and target board and I found a braided sleeve on a shelve.
("Open image in new tab" to see a bigger picture)
All wires initially have equal lengths so after assembling they are naturally indexed.
Five nested shrinkable tubes made the edge.
The final look reminds me something...
-Given: 496
« Reply #1 on: July 31, 2018, 11:41:13 23:41 »
That is sexy.
But same color wire.. hmm confusing at the end point.
Signal
-Given: 113
-Receive: 81
« Reply #2 on: August 01, 2018, 01:28:17 01:28 »
That is sexy.
Colored wires definitely would be sexier. But could be too sexy ;)
PTFE isolation has its advantages and I love it. Not many colors for PTFE isolated wires. That is why here they are length-indexed - shortest is No.1, next - 2, longest is No.8. That is enough at soldering time. And even more than enough - such way is easier than to remember which color is for.
To be completely honest... the same length wires twisted in one cord result the aligned ends in case of 5 wires. in case of 8 wires one wire is in the middle and is untwisted, and thus passes a shorter path - at the end it is quite longer (in my case about 3 mm for 8 wires and 1.5mm for 6 wires) that could be corrected.
« Reply #3 on: August 01, 2018, 11:45:37 23:45 »
really nice work :-D
