December 21, 2024, 01:14:11 13:14
Author Topic: sharing a project with mcp73833 li-ion charger  (Read 3237 times)
sphinx
-Given: 614
-Receive: 271
« on: May 24, 2018, 12:31:58 12:31 »
I am sharing a MCP73833/4 based design with a header to be able to quickly
change the charge current for the battery.
Be sure to read the info on the schematic sheet. Download the datasheet
from microchip for info on the chip.
Design is made in altium, 2-layer board with 1206 size for easy hand soldering.
You can of course change for your own desires/wishes.
P.S. There are some errors/warnings with the usb connector i can not figure out how to fix those.
now when i check there are no errors, be sure to do a "Design Rule Check"
« Last Edit: May 24, 2018, 04:42:10 16:42 by sphinx » Logged
sphinx
-Given: 614
-Receive: 271
« Reply #1 on: May 27, 2018, 12:25:23 12:25 »
Updates to the project and made another project without usb port
made some tweaks.
