April 02, 2025, 10:38:56 10:38
Author Topic: MAX30100 Pulse Oximeter and Heart-Rate Sensor IC  (Read 4956 times)
pbraida
-Given: 187
« on: May 14, 2018, 01:47:29 13:47 »
Hello all.
I don't know if this is the right place to put this message.
If not sorry in advance.
Anyone had expirience with this IC or had another indication ?
I need to use this or any other ic in a blood analyse project, i need to know the O2% and blood temperature.
The basic question is this works well, it is stable,  any recomendations ?
Thanks.
Pedro.
-Given: 231
-Receive: 990
« Reply #1 on: May 14, 2018, 03:08:21 15:08 »
Be careful this circuit was discontinued for about a year ago. It has a replacement MAX30101/MAX30102. If it is a school project and you are sure you can get still get plenty circuits just use it. But for a new commercial product I would not have used it
rosetta
« Reply #2 on: May 14, 2018, 04:40:46 16:40 »
Hi Pedro,
I am not sure if you are looking for an IC to create a new product or you are working on a one-off unit. If this last is the case, you can get a very cheap pulsioximeter that has internal serial data that you can read easily. I was working in a (for fun) project and getting the data out was quite easy, you can then do whatever you need with it.
I haven't done an article yet, but it is very similar to this: http://www.thinkering.de/cms/?p=864
You don't need to get a pulse oximeter with serial output, the data is available inside anyway, in a pulse oximeter like this one (for example):
https://www.amazon.com/Innovo-Fingertip-Oximeter-Plethysmograph-Perfusion/dp/B01NATPX6I/ref=sr_1_6_a_it?ie=UTF8&qid=1526312381&sr=8-6&keywords=pulse+oximeter
rosetta
pbraida
-Given: 187
« Reply #3 on: May 15, 2018, 03:30:15 15:30 »
Sideshow Bob.
This sensor is for a commercial product and i din't know that was discontinued.
I will try the MAX30101/MAX30102.
Thanks for your advice.
Pedro.
Posted on: May 15, 2018, 08:45:55 08:45 - Automerged
Hi Rosetta,
I am looking for a sensor for commercial  product i need to measure the blood temperature, this MAX sensor has this feature.
Your links are a good ideas for my product.
Thanks.
Pedro.
