April 05, 2025, 08:43:51 08:43
Author Topic: Req: Pcb data file for mk-3965 power supply  (Read 5211 times)
max
-Given: 1710
-Receive: 52
« on: February 06, 2018, 09:30:54 21:30 »
Requires pcb data or gerber file for the mk-3965 power supply project.
see the attached pdf.
-Given: 841
-Receive: 4366
« Reply #1 on: February 06, 2018, 10:47:40 22:47 »
Here is full Article
with pcb layout in PDF
bigtoy
-Given: 340
-Receive: 297
« Reply #2 on: February 07, 2018, 11:04:31 23:04 »
Be warned there's an obvious error in the schematic (which is fixed in the PCB layout). See attached file.
max
-Given: 1710
-Receive: 52
« Reply #3 on: February 09, 2018, 08:49:25 20:49 »
It is possible to convert the pdf or image data to gerber data?
Unhappy
-Given: 1006
-Receive: 101
« Reply #4 on: February 10, 2018, 07:29:08 07:29 »
Try using sprint PCB and associated software to convert pdf to pcb file and then export your Gerber.
Search for Sprint PCB in Sonsivri forums and you will find it Grin
Additionally look here for complete tutorial
http://www.sonsivri.to/forum/index.php?topic=34228.msg178821#msg178821
« Last Edit: February 10, 2018, 07:39:43 07:39 by Unhappy » Logged
papy_bidouille
-Given: 133
-Receive: 22
« Reply #5 on: February 10, 2018, 07:57:15 07:57 »
 you can do the following:
convert the PDF file to a GERBER file using Gerbview
 the resulting GERBER file into Sprint Layout which allow snapping to  ...
 center of a pad
 try to guess the diameter of each pad on the  ...
 with the right hole size
export the Excellon file.
-Given: 231
-Receive: 990
« Reply #6 on: February 10, 2018, 08:52:43 08:52 »
FAB 3000 is a software that do this. Is a software that can do this. If it is a one time job. Perhaps you can use the trail version for this
https://www.numericalinnovations.com/collections/fab-3000-gerber-cam. We also had a thread about this software here
http://www.sonsivri.to/forum/index.php?topic=33913.75 But it has not been used much recent years, and links may be dead. However this circuit is designed around the LM723 type IC. You will find tons of designs around this circuit on the net
« Last Edit: February 11, 2018, 10:20:23 10:20 by Sideshow Bob » Logged
max
-Given: 1710
-Receive: 52
« Reply #7 on: February 14, 2018, 09:17:10 21:17 »
Here is the gerber and sprint files of the pcb (copper side)
the gerber is generated using ace3000.
