April 26, 2025, 11:15:01 11:15
Author Topic: AVRco last Upload REV 4.89.00 Nov.05.2007  (Read 10274 times)
zetd
-Receive: 32
« on: November 17, 2007, 02:38:29 02:38 »
http://www.e-lab.de/AVRco/index_en.html
Pascal-scm for Atmel AVR
Multi-Task Developmentsystem for Atmel's AVR© RISC CPU's 90S2313..mega256
AVRco ...
    * has a powerful project-oriented multi-window editor with syntax and error Highlight, Online help
    * Application assistent for interactive design of the application. Generates source code.
    * Pascal-Compiler supports processes, tasks, interrupts and onChip peripherals. 16- and 32bit Integer
    * includes IEEE floatingpoint , trigonometric and logarithmic functions.
    * has extensive bit manipulation. Driver for I2C-Bus, LCD-Display, 7-seg LED-Display, RS232, Stepper, LAN
    * Assembler, also for machine code in the Pascal-Source
    * contains as a Bonus an own Simulator for Multitask Debugging
    * comes with an included InCircuit Programmer + JTAG Debugger
    * 1 year of free updates/downloads, a fee of 25% of the actual price for each additional year
    * not VISTA compatible at this time
Free Standard release of AVRco
    * Limited to appr. 4kB Flash code.
Free Mega8/Mega48 release of AVRco
    * Limited to mega8/88 and 8kBytes of flash code.
    * With completely implemented Pointers, Arrays, Records, BitSets etc. Give it a try and enjoy it. You will not be disappointed. With 5 complete manuals
    * If you encounter any errors or problems, send an e-mail with a short description and some source lines. We will immediately put a revised update on our homepage for download. Always take a look at the displayed update date.
Profi version Release with Mega256 + Units + LCD-Graphic + TCP/IP + FAT16 FileSystem
    * already implemented:
          o Units in Borland Style, Sound driver, LCD graphics driver, Heap management, Table Interpolation, EtherNet Stack xUDP, FAT16 FileSystem
    * many future enhancements
Merlin Optimiser
    * Support tool
    * Optimiser Plug-in for the Standard and Profi version
    * reduces the code size between 5% and 20%
    * included in REV4.xx
pls share it to us
Dreams really do come true, when home robots do the dirty work for me. everythink is free, no war, no poison on my earth, everyone share thinks but not with my pretty girls,powered by science and humanity not by "dazzle think" - welcome to the planet of earth -
gosu
« Reply #1 on: November 21, 2007, 01:43:21 01:43 »
avr-stusio
fish
« Reply #2 on: November 21, 2007, 02:02:46 02:02 »
How different is this avrco compare to MikroPascal ?
s_ch
« Reply #3 on: November 21, 2007, 06:40:09 06:40 »
this avrco no have crack. and limited 4k code generation ( generate full code only mega8). Sad
nanocycle
« Reply #4 on: November 21, 2007, 11:38:02 11:38 »
My firend.Is it possible to put a tutorial of avrco,because it found it hard for start.
regards'
venda
-Given: 562
-Receive: 89
« Reply #5 on: November 21, 2007, 04:38:08 16:38 »
All documents you can find and download from:
http://www.e-lab.de/downloads/index_en.html
zetd
-Receive: 32
« Reply #6 on: November 21, 2007, 09:47:02 21:47 »
Quote from: fish link=topic=6526.msg31351#msg31351 date=
- AVRco have internal library for multitasking and NET stuff, not exist on MikroPascal
- Have you test it both? i had it (... little bit), and i can say, close to real syntact for pascal programming in
  AVR is AVRco, its great, including optimizer for producing dense and optimize code to burn.
« Last Edit: November 21, 2007, 10:40:43 22:40 by zetd » Logged
KhepeleSibilo
Translator
-Receive: 412
« Reply #7 on: November 27, 2007, 09:50:15 09:50 »
see :
http://www.sonsivri.com/forum/index.php?topic=1424.msg7339#msg7339
and download :
http://rapidshare.com/files/53243369/AVRco_4.79.rar
zetd
-Receive: 32
« Reply #8 on: November 27, 2007, 10:19:36 10:19 »
Hi wolf1359,
I had download the software, looks good, but from sample project, AVR FatMMC, when i build it, there is an error ... Error : Internal Compiler Error
What thats error?
Cracks not works ? or bad in project ?
« Reply #9 on: November 27, 2007, 10:29:39 10:29 »
The crack doesn't seem to be working.
KhepeleSibilo
Translator
-Receive: 412
« Reply #10 on: November 27, 2007, 11:28:07 11:28 »
dear zetd
this is the only crack witch i could find in last 5 year  Cry
also one for ver 2.5xx witch is not include FAT and some other options  Embarrassed
also i am looking for a good crack,with this crack some limits are gone but they are several problems  Cry
kikilcom
« Reply #11 on: December 18, 2007, 12:58:07 00:58 »
it is hard to make a start using this compiler..sure i am a pascal fans... , and few hobby level users are using it
venda
-Given: 562
-Receive: 89
« Reply #12 on: February 17, 2008, 01:02:30 13:02 »
you can download and try to test AVRco version 4.93 from eDonkey link
ed2k://|file|elab_AVRCo_Profi_4.93.rar|39021518|B2F35CDC8753A0A8D36FE0FA309F2D76|/
kikilcom
« Reply #13 on: February 27, 2008, 02:09:53 14:09 »
Downloaded previous version , but it seems very complicated, and difficult
for beginners to start writing codes. we need some compilers that can be
understood in hours instead of days.. i do love Pascal Language..
orange
-Given: 702
-Receive: 204
« Reply #14 on: September 22, 2008, 12:54:20 00:54 »
Avrco v4.93
http://rapidshare.com/files/146855275/el4.93.rar
smartcat004
-Receive: 27
« Reply #15 on: September 22, 2008, 12:39:06 12:39 »
The software package sells bundled with its own JTAG and ISP hardware.
Nice compiler libraries and 'realtime' style framework. Helps  to lower the barrier to get a RTOS running in chips.
I looked thru the pdfs and there is no mention it supports the Atmel USB-JTAG. So debugging real apps may be some challenge.
quadro
« Reply #16 on: September 22, 2008, 01:28:37 13:28 »
@venda,
Can you upload that edonkey 4.93 Pro version to rapidshare.
I tried the cracked mega8 version that was posted on rapid few days ago but I get to many errors with trying the samples so I think it is not good.
The current version is 4.93.15 and there are number of improvements/bugfixes between 4.93 and 4.93.15
mick
-Given: 2111
-Receive: 123
« Reply #17 on: September 22, 2008, 09:51:31 21:51 »
mega8  is free version
Codeman
-Given: 31
-Receive: 20
« Reply #18 on: September 23, 2008, 10:47:14 10:47 »
I compiled several examples with the version posted (4.93). No erros here. Dind't tested with actual hardware.
quadro
« Reply #19 on: September 23, 2008, 11:29:53 11:29 »
@mick,
Yes the mega8 is free version but you have here http://www.sonsivri.com/forum/index.php?topic=15111.0 4.93 that is basically mega8 install with changed avcro.exe and pass.
