November 28, 2024, 08:01:04 20:01
Author Topic: 3D-Tool - 3D/2D CAD Viewer and CAD Converter  (Read 5160 times)
mars01
-Given: 697
-Receive: 1774
« on: November 26, 2017, 02:59:32 02:59 »
3D-Tool 12.20 Premium
The CAD-Viewer and Converter from 3D-Tool has useful tools to analyze 3D models without CAD knowledge. At the push of a button, 3D-Tool provides the dimensions, the surface area and the volume for all parts of a model. Distances, angles and radii can be measured with simple mouse clicks.
Converting 3D CAD files
The 3D-Tool Premium version also features the 3D-NativeCAD Converter to convert 3D CAD files into common 3D exchange formats.
The 3D-NativeCAD Converter (3D-Tool Premium only)
The converter simplifies the data exchange with customers and suppliers whose file formats are not supported by the existing CAD system.
3D CAD file formats supported by the 3D-Native CAD Converter
Features of the 3D-NativeCAD Converter
The 3D-NativeCAD Converter converts 3D CAD models of the CAD systems CATIA, Pro/Engineer, Creo, UG/Siemens NX, SolidWorks, SolidEdge and Inventor to CATIA V4/V5, STEP, IGS, VDA, SAT/SAB, X_T, or STL.
For assemblies particular parts and subassemblies can be selected or deselected for conversion in the model tree.
The file version of the output file can be selected, when converting to CATIA V5, SAT, SAB, and X_T.
For SolidWorks and Creo models, existing Configurations and Simplified Representations can be selected for conversion.
Additional converter options allow filtering points, curves, and hidden elements during conversation.
For me it's useful to convert 3D models found online in formats not recognized by Altium Designer into the STEP format which can be used in Altium Designer (and in Altium Circuit Studio).
« Last Edit: November 26, 2017, 03:02:42 03:02 by mars01 » Logged
StefDrums
-Given: 22
« Reply #1 on: January 30, 2018, 01:45:26 13:45 »
I used the 10.05 version and it is very useful!
btw, I think that your links are broken.
Bye.
mars01
-Given: 697
-Receive: 1774
« Reply #2 on: January 30, 2018, 01:49:15 13:49 »
Bye.
Links like that have a limited lifetime. In this case it was 30 days. If you need this software I can reupload it on ufile.io, but I won't waste time unless you need it.
lecroy
-Given: 75
-Receive: 34
« Reply #3 on: January 30, 2018, 02:14:10 14:14 »
To save you uploading there's a copy on downloadly if (s)he needs it.
StefDrums
-Given: 22
« Reply #4 on: February 01, 2018, 01:43:54 13:43 »
Yes, if you can upload I will appreciate because it is newer than the version I tried.
Thanks!
mars01
-Given: 697
-Receive: 1774
« Reply #5 on: February 01, 2018, 05:26:09 17:26 »
Reupload.
Ufile.io link. 30days lifetime.
