November 25, 2024, 07:26:02 07:26
Author Topic: Strange DC results with Orcad V 17.2  (Read 3671 times)
PM3295
-Given: 358
-Receive: 155
« on: July 31, 2017, 05:37:05 17:37 »
I found something strange with the DC simulation results using V 17.2
It may be a bug; I don't know. If I simulate the same circuit with V 16, the Ic of Q1 goes up with temperature, while in V 17.2 it decreases as shown.
If I use another simulator like TINA-TI, the Ic also increases with temperature, similar to V 16.
I would expect Ic to increase with temperature. Any ideas?
optikon
-Given: 1106
-Receive: 2007
« Reply #1 on: July 31, 2017, 10:01:35 22:01 »
Different models are being used between v16 and v17? one of them might be using a model that doesnt have all the parameters populated (defaults=zero etc..)
Can you verify that the same model is used for 2N3904 ?
PM3295
-Given: 358
-Receive: 155
« Reply #2 on: July 31, 2017, 10:48:45 22:48 »
I don't have access to V 16 at the moment.  I did look at the V 17 model, and almost all the parameter fields have a non-zero entry. Creation date 2001
I decided to try with another common NPN transistor (2N4401) and got the same reverse trend for Ic. So it may not be a model problem.
