November 25, 2024, 06:46:51 18:46
Pages: 1 [2]  All
Author Topic: Ccs 3.241  (Read 23024 times)
J1M
« Reply #25 on: January 08, 2006, 05:44:28 17:44 »
It´s very xtrange, ive compare files (with WinHex) from version 3.227 and cracked by metal from version 3.241 and.... they are the same files... Then if i put cracked files from 3.236 version in 3.241 installation folder its the same result, compiler tell that its 3.241 and its not true.
My recomendation to all its that dont install this crack, its like do nothing.....
no comments about trojan of course....
Metal what r u doing? :confused:
The question is if compiler should work fine with an ancient IDE, if this is true and i think this is metal thougths his 'crack' its ok, although its based on cracked exes from 3.227 version. A REAL crack should be based on 3.241 IDE, at the moment im working on it.
pd: PICOL por cierto, a veces no 'todo llega', hay q ir a buscarlo Wink es un consejo.
saludos Smiley
« Last Edit: January 08, 2006, 06:07:15 18:07 by J1M » Logged
« Reply #26 on: January 08, 2006, 07:32:46 19:32 »
First, no need to be angry about such a thing and start attacking me, take it easy guys, its a software we are trying to crack after all.
Second, the Ccse.exe file is cracked and you can check that your self J1M, any way the problem seems to be in Pcw.exe v3.241 which I cracked, I followed the way Pcw.exe v3.227 was patched, and tried to do the same on Pcw.exe v3.241 taking the different offsets and values that had to be changed into consideration, there were many differences in deed, and this is the best I could achieve till now.
Regarding the file in windows folder, I received from a friend a disassembler tool last week which can use (Inno setup software) to build a setup in order to install the cracked files (Pcw.exe & Ccsc.exe & 3 REG files) directly to the software folder (PICC). I have modified the exe files using that tool, and it built the setup for me, eliminating the need to use a patch, and seems I was wrong because this has put me in an embarrassing situation now. I have not discovered there was a file added to the setup till parallax posted to inform us, I don't even know what this file does, as a matter of fact, I use deep freeze and don't need an antivirus, so I don't usually pay attention to viruses. And as you all can see, I have already posted many cracked exe files, and there was no problems reported, I mean that I had no intention to do any thing bad here.
Next time, if there is a next time any way, I will post a patch to avoid such confusing arguments and situations.
MetaL
« Last Edit: January 08, 2006, 07:49:28 19:49 by metal » Logged
pak
« Reply #27 on: January 09, 2006, 01:01:37 01:01 »
I have tested the software from
http://rapidshare.de/files/10441018...pd3241.zip.html with following files. Try it.
pak Smiley
J1M
« Reply #28 on: January 09, 2006, 01:29:18 01:29 »
lol Cheesy this is a good crack yes xDDD registration files rules! Smiley
thank u very much pak Wink
a mirror:
http://rapidshare.de/files/10688718/CCS_PCWH_3.241_and_reg_files.zip.html
regards!
« Last Edit: January 09, 2006, 01:49:35 01:49 by J1M » Logged
newbaby
« Reply #29 on: January 09, 2006, 11:32:08 11:32 »
Hi Metal,
You have done a very good thing to us so far.We know that you did not mean to do any harm so do not feel bad about that.
every body should appriciate what he has done so far in this forum so we have things to use.CRACK mean TRYING .Please do not point finger to the one who try to help when it is not perfect yet.
New baby
PICOL
« Reply #30 on: January 09, 2006, 02:54:49 14:54 »
Gracias J1M.
PICOL
« Last Edit: January 16, 2006, 03:37:08 15:37 by PICOL » Logged
« Reply #31 on: January 09, 2006, 04:04:57 16:04 »
thank you all guys, newbaby for being supportive, parallax for pointing to the starnge file and correcting things, other for the license files Smiley
J1M
« Reply #32 on: January 09, 2006, 08:47:11 20:47 »
first of all, metal sorry for my words and for dont reply yesterday to your post.
I dont know u and i admit that i was too much rude. My point of view were that somebody posted a 'crack' that had a troyan inside, that said that has cracked 3.241 when in reallity ccsc.exe and pcw.exe are from 3.221 version well i just was ungry. So and when at least the storm has finished i just want to say you sorry if my words offended to you.
Well thanks for you contrubution too, altough... change your packer Wink
regards and peace br0 Smiley
« Reply #33 on: January 09, 2006, 10:31:18 22:31 »
J1M
I already did that today, as I changed the way I pack cracks from now on.Goto this thread and download the latest                           Patch I released today upon PMs and on-line requests.
Just to let you know J1M, version 3.221 has nothing to do with the patched 3.241 exe files I posted yesterday, I will talk to you on private, it was a tricky way, but appeared to be not completely effective with both cracked files, as happened to the patched Pcw.exe 3.241. By the way, can you post a patch for new mikroelektronika AVR compiler, I will be waiting for that patch.
J1M
« Reply #34 on: January 09, 2006, 11:00:12 23:00 »
Hi Wink
Cool patch engine, I used to use CodeFusion3.
About AVR compiler, sorry but im not an experienced cracker and im going to start february examns :S, really im only made patch for 3.221, 3.227, 3.235, 3.236 CCS, and like you know this versions are really really easier to be patched.
Sorry, were i said 3.221, want to say 3.227. But now it doesnt matter.
« Last Edit: January 09, 2006, 11:05:30 23:05 by J1M » Logged
Zaphod Beeblebrox
-Receive: 103
« Reply #35 on: January 10, 2006, 10:07:18 10:07 »
Thanks a lot for the license files Smiley
Black holes are where the God divided by zero...
Don't panic!
smersh
« Reply #36 on: January 11, 2006, 05:34:36 17:34 »
PalitroqueZ!!
Well done! works just fine.
« Reply #37 on: January 11, 2006, 06:10:06 18:10 »
Hey PalitroqueZ
Great work, you seem to be well experienced in keygen artwork and algorithm reversing, nice to have you on forum Smiley
J1M
« Reply #38 on: January 11, 2006, 06:15:27 18:15 »
oleee! jjeje creo q es el primer keygen para el CCS que se deja ver, enhorabuena PalitroqueZ y pedazo aparición Wink gracias!
At least ive made a patch for 3.241 if there are anybody interested on it ill post in forum... but with a keygen... no patches are neccesary! Wink
« Reply #39 on: January 11, 2006, 06:29:02 18:29 »
Hey J1M
I am intrested Smiley
J1M
« Reply #40 on: January 11, 2006, 07:28:22 19:28 »
hi men Wink
here u have, patch to use with old .reg files (like monash univ Wink)
http://rapidshare.de/files/10862347/patch_3.241.zip.html
regards!
« Reply #41 on: January 11, 2006, 07:36:38 19:36 »
Hey J1M
Nice work you did man Smiley Congratulations !!
TCU
« Reply #42 on: January 12, 2006, 07:58:12 07:58 »
Thanks all
work work
PCWH, Pacth, and KeyGen
RA&RA
« Reply #43 on: January 12, 2006, 12:03:26 12:03 »
Nice job, thanx...
Aşağıda olan yukarıda olan gibidir, ve bir şeyin mucizesini gerçekleştirirler
project_maker
« Reply #44 on: January 12, 2006, 12:40:13 12:40 »
Hi PalitroqueZ, Metal
Please make crack or keygen for FLEXHEX 1.4 (http://www.flexhex.com/download/). I want to use this software but demo version can use 30 days only.
Thank.
TCU
« Reply #45 on: January 14, 2006, 07:28:07 07:28 »
Here --> http://z29.zupload.com/download.php?file=getfile&filepath=4310
Pages: 1 [2]  All
