koky
-Receive: 157
« on: January 04, 2006, 08:04:45 08:04 » |
TCU
« Reply #1 on: January 04, 2006, 09:51:59 09:51 » |
need 3.241
lanyong
« Reply #2 on: January 04, 2006, 11:26:01 11:26 » |
The topic or post you requested does not exist
swapgo
« Reply #3 on: January 05, 2006, 10:40:51 10:40 » |
Hi All
The Link is wrong. Regards Gopi
koky
-Receive: 157
« Reply #4 on: January 05, 2006, 12:59:54 12:59 » |
i try tu upload
koky
-Receive: 157
« Reply #5 on: January 05, 2006, 01:14:24 13:14 » |
pak
« Reply #6 on: January 06, 2006, 01:16:18 01:16 » |
Hi koky, Is it working? I have problem with ""cwhupd3241.exe" that I download from rapidshare. Any solution? The following link is demo version of ccs. I find that the file size is different. http://www.ccsinfo.com/demo.shtml Regards, pak
« Reply #7 on: January 06, 2006, 02:18:48 02:18 » |
This is not a demo, but it needs a crack, or up to date licenses.
Where are the licenses, and cracks ??
J1M
« Reply #8 on: January 07, 2006, 02:30:37 02:30 » |
this version is different from the others (3.236, 3.235, 3.227, etc.) I cant make a patch for it :S, anyone experienced on cracks???
saludos
« Reply #9 on: January 07, 2006, 04:00:29 04:00 » |
I tried previous cracks, but they ain't work at all.
I also tried to crack the compiler itself and make a patch, but seems they are using another way now, its too high for my cracking skills unfortunatelly.
lanyong
« Reply #10 on: January 07, 2006, 09:36:32 09:36 » |
u can copy the *.dll of 3.241 to 3.235 have a good time
lanyong
« Reply #11 on: January 07, 2006, 01:04:45 13:04 » |
copy ccs 3.241's dll folder repeat ccs 3.235(cracked)'s dll folder. then run ccs 3.235's pwm.exe. then click help-->about
lanyong
« Reply #12 on: January 07, 2006, 01:09:07 13:09 » |
sorry pcw.exe
kittythai
-Given: 560
-Receive: 104
« Reply #13 on: January 07, 2006, 05:43:37 17:43 » |
Hi. Metal please check email on yahoo
J1M
« Reply #14 on: January 07, 2006, 06:18:33 18:18 » |
kittythai you´ve found a solution? ill be very gratefully if u could share it. [email protected] ill put it in eMule and rapidshare. thanks
koky
-Receive: 157
« Reply #15 on: January 07, 2006, 07:37:37 19:37 » |
seem to be a crack, i'm dowloading now
ed2k://|file|CCS_PCWH_3.241_and_patch.zip.zip|9370949|0cc98a674e9acd13f214a6d9de4948c0|
PICOL
« Reply #16 on: January 07, 2006, 11:53:11 23:53 » |
Paciencia J1M, ya llagará.
PICOL
PICOL
« Reply #17 on: January 07, 2006, 11:54:27 23:54 » |
Paciencia J1M, ... ya llegará.
« Reply #18 on: January 08, 2006, 04:01:03 04:01 » |
Hi The cracked exe files were deleted, parallax has sent me the strange file (Configuring.exe). I tried to know what it does, but I couldn't. Any way, no problem, seems we got license files now, hence, we don't need to patch any thing at the moment MetaL
« Last Edit: January 09, 2006, 03:56:17 15:56 by metal »
picelec
-Given: 15
-Receive: 32
« Reply #19 on: January 08, 2006, 08:00:32 08:00 » |
ah ah ah , the crack of MetaL is the old ide.
lanyong
« Reply #20 on: January 08, 2006, 11:44:32 11:44 » |
no perfectly:)
« Reply #21 on: January 08, 2006, 02:19:12 14:19 » |
picelec, The supplied crack is the 3.241 IDE. I wanted to see if I can change text and appearance in the cracked exe about dialog, and fortunatelly I succeeded, thats all. Also Ccsc.exe is cracked, and it shows that it is 3.241 I have not tried using the cracked 3.227 IDE in deed, you did really surprised me, I waill try to use it and see what the result will be.
pama
-Receive: 28
« Reply #22 on: January 08, 2006, 03:17:59 15:17 » |
Thanks Metal, I'll try your work. pama
parallaxis
« Reply #23 on: January 08, 2006, 04:46:24 16:46 » |
It seems to there is some strange in that crack, MetaL... My AV found suspicious file "windows\configuring.exe" launched by (and created by) cracking EXE file, identified as "Trojan horse generic/GI"...
« Reply #24 on: January 08, 2006, 05:42:23 17:42 » |
Seems to be added by the patching tools I am using, please don't download the crack, sorry for disturbance.
« Last Edit: January 08, 2006, 07:33:37 19:33 by metal »
