April 17, 2025, 11:22:13 11:22
Author Topic: Code compiling issue  (Read 5154 times)
ahmed
-Given: 101
-Receive: 605
« on: July 19, 2017, 03:14:23 15:14 »
Hello all,
I found this frequency counter code over internet , its an assemble language code , i already worked with assemble codes but have very short knowledge about assemble
So the hex file with the package works fine on simulator , but i have to add some things also need to edit lcd pins for this code. But MPLAB and MPASM gives me errors while compiling , also the errors are about syntax mostly. I searched alot about this matter but nothing found.
Please help me identifying this code's compiler , or please help me compiling this code.
Files are attached.
-Receive: 4367
« Reply #1 on: July 19, 2017, 04:32:23 16:32 »
Looking at the *.asm file its standard Assemble Code, as in most data sheets. as its for a 16F84 get a early copy of Mplab of 20 yaers back.
http://ww1.microchip.com/downloads/en/DeviceDoc/51519B.pdf
h0nk
-Given: 248
-Receive: 233
« Reply #2 on: July 19, 2017, 06:48:13 18:48 »
Hello Ahmed,
looks like parallax assembler code. It was sold to Tech-Tools.
Take a look at: http://www.tech-tools.com/picmicro-downloads.htm
If You want to rewrite the source, differences explained here:
http://mondo-technology.com/format.html
Best Regards
hexadec
-Given: 67
-Receive: 113
« Reply #3 on: July 20, 2017, 07:32:07 19:32 »
If you're interested I have a working project (years old) plus schematic for a frequency counter using a 16F84A.
I'll upload if you want it.
PS Just to confirm, your file won't compile on MPLAB
Sponge.
I'm allowed to have it 'cos it's not sharp.
ahmed
-Given: 101
-Receive: 605
« Reply #4 on: July 21, 2017, 03:56:41 03:56 »
Hello Ahmed,
Best Regards
I think this code is for custom compiler/assembler , it even not working on CVASM , also tried to change the compiler directives , but no still no. have you tried this code by yourself ? if not pls give it a try
Yes this is the main issue , MPLAB isn't recognizing this code. Syntax is different.
And yes i want to try , pls upload also if you worked on that project will that code run with MPLAB ?
h0nk
-Given: 248
-Receive: 233
« Reply #5 on: July 21, 2017, 09:49:06 21:49 »
Hello Ahmed,
if You look into the header file "16F84_32.txt" You will find the clue:
AKIZUKI's assembler.
I was not aware of this assembler. AKIZUKI seems to be a company in
Japan which sells Evalboards for PIC and some other microcontroller.
The 'ds' pseudoinstruction was also used by the parallax assembler,
so this was my first guess after i took a look into the main source.
The note regarding the assembler is only in the include file...
The AKIZUKI-assembler seems unavailable today. The examples of
AKIZUKI-evalboards use MPASM now.
Perhaps some boardmember from Japan has this software still on his harddisk.
Good luck and
Best Regards
Checksum8
-Given: 125
-Receive: 102
« Reply #6 on: July 21, 2017, 11:31:05 23:31 »
Here is a good one. I built the kit back in the 90's. "Weeder frequency counter" uses standard Microchip assembler
http://www.piclist.com/techref/piclist/weedfreq.htm
ahmed
-Given: 101
-Receive: 605
« Reply #7 on: July 22, 2017, 02:38:30 14:38 »
Hello Ahmed,
Good luck and
Best Regards
Finally with help of your advise about that compiler/assembler , now i am finally able to compile that asm file with success.
The main issue was header file that included by author , a little modification in that file make me successful.
Best Regards.
If anyone interested i can upload the whole project Smiley
