February 12, 2025, 04:51:34 16:51
Author Topic: attiny13 cant read adc input (isis simulation)with bascom avr  (Read 5267 times)
picavr
-Given: 267
-Receive: 101
« on: July 02, 2017, 05:10:14 17:10 »
the attiny13 cant read adc input (isis simulation)
the programme is writen in bascom avr Embarrassed Embarrassed
sfiga69
-Given: 201
-Receive: 160
« Reply #1 on: July 02, 2017, 08:40:40 20:40 »
ADC readings are missing because you miss START ADC.
I tried with Proteus 8.3 Sp2 and Bascom AVR 2.0.7.8 by putting START ADC after CONFIG ADC and the relay outputs change status
picavr
-Given: 267
-Receive: 101
« Reply #2 on: July 02, 2017, 10:46:08 22:46 »
no it work nt ...the adc input is considired like digital input
all two outputs change in a same time...but it must change indepently with a analog input
$regfile = "attiny13.dat"
$crystal = 4800000
  $hwstack = 10                                             ' default use 32 for the hardware stack
$swstack = 10                                               'default use 10 for the SW stack
$framesize = 10
' $noramclear
'Config Portb = Output
'bit7 6 5 4 3 2 1 0  ...... 1 out ,0 in
  Config Portb = &B11101111
  Config Timer0 = Pwm , Prescale = 1 , Compare A Pwm = Clear Up
       Config Adc = Single , Prescaler = Auto , Reference = Internal
      Start Adc
       Reset Admux.0
       Set Admux.1
  Dim Idd As Word
                                                'Alias Pinb.1
  Relaisout1 Alias Portb.1
   Relaisout2 Alias Portb.3
   Idd = Getadc(2)
Do
 Idd = Getadc(2)
 Waitus 100
 If Idd > 500 Then
 Relaisout1 = 1
  End If
  If Idd < 500 Then
 Relaisout1 = 0
  End If
  If Idd > 800 Then
 Relaisout2 = 1
  End If
  If Idd < 800 Then
 Relaisout2 = 0
  End If
Loop
'rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
End
« Last Edit: July 03, 2017, 02:12:14 14:12 by metal » Logged
o2
-Given: 40
-Receive: 405
« Reply #3 on: July 03, 2017, 12:59:35 12:59 »
internal ref=1.1V
picavr
-Given: 267
-Receive: 101
« Reply #4 on: July 03, 2017, 06:26:58 18:26 »
yes yes this is the problem
Config Adc = Single , Prescaler = Auto , Reference = avcc
now it work fine
