February 12, 2025, 11:09:16 11:09
Author Topic: Problem importing models into Micro-Cap  (Read 8623 times)
LithiumOverdosE
-Given: 383
-Receive: 588
« on: May 20, 2017, 11:10:08 23:10 »
For most things related to simulation I find Proteus more than adequate.
However, from time to time a need arises to simulate more complex parts and to use PSpice models
and Micro-Cap is suitable for that.
So far, I haven't had any problems importing manufacturers models into MC.
However, this time around I'm stuck with two models that make MC throw error when trying to use them.
While I do now some basics of Spice modelling, I find MC manuals lacking depth regarding peculiarity of supported syntax.
Of course, I tried searching the net for some useful info that doesn't require steep learning curve but with no luck.
My guess is that the problems are related to some aspect of Spice/PSpice syntax so perhaps someone
more proficient in Spice/PSpice syntax may suggest some solution or point me into correct direction.
1. The first model is small NE-2 gas discharge bulb.
While Proteus have a good enough model of it, of course the source is closed so no luck peeking into it.
I have found surprisingly small number of articles on topic of NE-2 simulation but one particular model is more or less
always circulating around and it seems good enough for my needs.
* Small Neon Lamp Behavioral Model Copyright 2003 by [email protected]
* Vs: strike voltage (bi-directional)
* Ii: threshold current boundary between strike and hold voltage
* Ti: ionization time constant of gas
* Vh: hold (regulation) voltage within normal current range
* Rh: on resistance within normal current range
* Ia: transition current to the increasing resistance of abnormal glow
.SUBCKT NE-2H A1 A2 PARAMS: Vs=130 Ii=50u Ti=1m Vh=80 Rh=1k Ia=4m
Varc A1 arc 0 ; current sense
Garc arc A2 VALUE = {sgn(V(arc,A2))*LIMIT((abs(V(arc,A2))-V(ref))/(Rh*V(abn)),0,1)}
Carc arc A2  5p ; stray terminal capacitance
Gref 0  ref  VALUE = {Vh+(Vs-Vh)/(1+V(ion)**2)} ;
Rpar=1 ; voltage transition
Rparref 0  ref  1;
Cref ref  0  1n ; tiny capacitance here aids convergence
Gion 0  ion  VALUE = {abs(I(Varc))} ;
Rpar={1/Ii} ; measure of free ions
Rpar 0  ion  {1/Ii}
Cion ion  0  {Ti*Ii} ; gas ionization time constant
Gabn 0  abn  VALUE = {Ia**2}+I(Varc)**2 ;
Rpar={1/Ia**2} ; abnormal glow
Rparabn 0 abn {1/Ia**2}
Cabn abn  0  1p ; tiny capacitance here aids convergence
.ENDS NE-2H
It looks like PSpice syntax and MC should be able to run it but when the sim starts I get following errors:
Warning: Part names have been changed.
RPAR1=1 changed to RPAR_1
following with
Error: Missing Nodes.
Part: X13.RPAR_1
File: C:\TEST.CIR
.Subckt: X13 calls NE-2H
To me it seems as if MC doesn't like assigning value to a Rpar for some reason but at this point I'm at loss on how to proceed further.
2. The second model are ordinary cheap MOSFET driver TC4429 which is successfully modelled in Proteus but not in MC.
Microchip offers PSpice models but they also make MC throw an error.
.SUBCKT TC4429 1 2 3 4
*                    | | | Negative Supply
*                    | | Positive Supply
*                    | Output
*                    Input
* Software License Agreement                                                   *
* The software supplied herewith by Microchip Technology Incorporated (the     *
* 'Company') is intended and supplied to you, the Company's customer, for use  *
* solely and exclusively on Microchip products.                                 *
* The software is owned by the Company and/or its supplier, and is protected   *
* under applicable copyright laws. All rights are reserved. Any use in         *
* violation of the foregoing restrictions may subject the user to criminal     *
* sanctions under applicable laws, as well as to civil liability for the       *
* breach of the terms and conditions of this license.                          *
* THIS SOFTWARE IS PROVIDED IN AN 'AS IS' CONDITION. NO WARRANTIES, WHETHER    *
* EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED        *
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO  *
* THIS SOFTWARE. THE COMPANY SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR    *
* SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.     *
* The following MOSFET drivers are covered by this model:
*      Rev A Testing - TC4429
* Polarity: Inverting
* Date of model creation: 1/26/2007
* Level of Model Creator: A
* Revision History:
*      12/24/07 HNV Created by edit of TC4423_I2D_A
*       2/28/08 HNV Updated quiescent current, adjust speed
* Recommendations:
*      Use PSPICE (or SPICE 2G6; other simulators may require translation)
*      For a quick, effective design, use a combination of: data sheet
*            specs, bench testing, and simulations with this macromodel
*      For high impedance circuits, set GMIN=100F in the .OPTIONS statement
* Supported:
*      Typical performance for temperature range (-40 to 125) degrees Celsius
*      DC, AC, Transient, and Noise analyses.
*      Most specs, including: propgation delays, rise times, fall times, max sink/source current,
*            input thresholds, voltage ranges, supply current, ... , etc.
*      Temperature effects for Ibias, Iquiescent, output current, output
*            resistance,....,etc.
* Not Supported:
*      Some Variation in specs vs. Power Supply Voltage
*      Vos distribution, Ib distribution for Monte Carlo
*      Some Temperature analysis
*      Process variation
*      Behavior outside normal operating region
* Known Discrepancies in Model vs. Datasheet:
* Input Impedance/Clamp
R1  4    1    2MEG
C1  4    1    38P
G3  3    1    TABLE { V(3, 1) } ((-770M,-1.00)(-700M,-10.0M)(-630M,-10N)(0,0)(20.0,10N))
G4  1    4    TABLE { V(1, 4) } ((-5.94,-1.00)(-5.4,-10.0M)(-4.86,-10N)(0,0)(20.0,10N))
* Threshold
G11 0    30    TABLE {V(1,11)}((-1m,10n)(0,0)(0.88,-.1)(1.5,-0.9)(2.2,-1)(4,-1.1)(6,-1.3))
G12 0    30    TABLE {V(1,12)}((-6,1.3)(-4,1.1)(-2.3,1)(-1.8,.9)(-0.7,.1)(0,0)(1,-10n))
R21 0 11 1 TC .3m 1.4u
G21 0 11 TABLE { V(3, 4) }
+ ((0,0)(4,1.34)(5,1.43)(6,1.5)(7,1.5)(10,1.48)(12,1.48)(18,1.5))
R22 0 12  1 TC .1m -0.8U
G22 0 12 TABLE { V(3, 4) }
+ ((0,0)(4,1.16)(6,1.24)(7,1.24)(9,1.23)(11,1.23)(18,1.25))
C30 30   0    1n
* HL Circuit
G31 0    31   TABLE { V(3, 4) } ((0,75)(5,43)(5.5,39.5)(6,37)(7,34)(8,32)(12,29.2)(17,29.8)(18,28.6))
R31 31   0    1 TC 3.2M
G33 0    30   TABLE { V(31, 30) } ( (-1m,-10)(0,0)(1m,5n)(1,10n) )
S31 31   30 31 30 SS31
* LH Circuit
G32 32   0    TABLE { V(3, 4) } ((0,31)(5,19)(6,18)(8.5,15)(11.5,14.4)(17,15.5)(18,15.4))
R32 0    32   1 TC 2.9M 10U
G34 30   0    TABLE { V(30, 32) } ( (-1m,-10)(0,0)(1m,5n)(1,10n) )
R30 32   30   1MEG
* DRIVE
G51  0 50 TABLE {V(30, 0)}
+((-5,-1n)(-3,-1n)(0,0)(5,6.8)(15,3.3)(30,4.5))
G52 50  0 TABLE {V(0, 30)}
+((-5,-1n)(-3,-1n)(0,0)(4,6)(13,3.2)(15,3.0)(22,2.7))
R53  0 50 1 TC -4m 12u
G50 51 60 VALUE {V(50,0)*0.8/(-0.2+18/V(3,4))+1m}
R51 51  0 1
G53  3  0 TABLE {V(51,0)} ((-10,10)(0,0)(1,1n))
G54  0  4 TABLE {V(0,51)} ((-10,10)(0,0)(1,1n))
R60 0    60   100MEG
H67 0    69   V67 1
V67 60   59   0V
C59 0    59   1.5N
C60 561    60   2N
R59 59   2   0.5
L59 59   2   5N
* Shoot-through adjustment
VC60        56 0 0V
RC60        56 561 1m
H60         58 0 VC60 56
G60P 0 3 TABLE { V(58, 0) }
+ ((-1,-1u)(0,0)(30,0.8)(100,1.3))
G60N 4 0 TABLE { V(0, 58) }
* Source Output
E67 67   0    TABLE {V(69, 0)}((-10,-10)(0,0)(10,50))
G63 0   63   POLY(1) 3 4 6 -280M 3M
R63 0    63   1 TC 3.3M,-2U
E61 61   65   VALUE {V(67,0)*V(63,0)}
V63 65   3    10.0M
G61 61   60   TABLE {V(61,60)}((-12.0M,-200.0)(-11.0M,-60)(-10.0M,-6)(0,0)(.1,5N)(50,10N))
* Sink Output
E68 68   0    TABLE {V(69,0)}((-50,-10)(0,0)(10,10))
G64 0   64   POLY(1) 3 4 3.45 -180M 2.7M
R64 0    64   1 TC 3.3M 6U
E62 62   66   VALUE {V(68,0)*V(64,0)}
V64 66   4    10.0M
G62 60   62   TABLE {V(60,62)}(-12.0M,-200.0)(-11.0M,-60)(-10.0M,-6)(0,0)(.1,5N)(10,10N))
* Bias Current
G55 0    55   TABLE {V(3,4)}((0,0)(4,296U)(6,338U)(13,410U)(17,500U)(20,750U))
G56 3    4    55 0 1
R55 55   0    1 TC  5.7M 19U
G57 0    57   TABLE {V(3,4)}((0,0)(4.4,48U)(6,54U)(7,64U)(13,68U)(16,70U)(20,78U))
G58 3    4    57 0 1
R57 57   0    1 TC  4.6M 49U
S59 55   0    1 0 SS59
* Models
.MODEL SS59 VSWITCH Roff=100MEG Ron=1m Voff=1.5V Von=1.2V
.MODEL SS31 VSWITCH Roff=100MEG Ron=800 Voff=0.2V Von=0.1V
.ENDS TC4429
However, resistors TC syntax seems to be bothersome for MC.
Error: Missing model statement 'TC'.
Part: X12.R21
File: C:\TEST2.CIR
.Subckt: X12 calls TC4429
I have tried putting TC values into square brackets as suggested in MC manual but with no luck.
There is something I'm missing but I'm not really sure what exactly.
Of course, the simplest solution would be to try models in PSpice but for some reason I have problem running it on the laptop
so for the moment I can use only MC.
Regrettably there seem to be limited resources on the net pertaining to peculiarities of MC so perhaps some of you have have some useful ideas.  Roll Eyes
optikon
-Given: 1113
-Receive: 2007
« Reply #1 on: May 21, 2017, 01:49:53 13:49 »
Have you narrowed down which particular lines are causing trouble?
When you remove certain lines or commands, the model wont run but does it eliminate the errors?
Once the errors are eliminated, we can re-write the problematic line using MC friendly syntax.
« Last Edit: May 21, 2017, 02:03:26 14:03 by optikon » Logged
LithiumOverdosE
-Given: 383
-Receive: 588
« Reply #2 on: May 22, 2017, 09:51:08 09:51 »
Thx for the reply.
1. Sure, I've narrowed it down to two "Rpar=1;" and "Rpar={1/Ia**2};" statements in the NE-2H model.
I commented those two statements and the model appeared to be simulating but with the wrong results.
What caught my eye is that B sources are not mentioned in the MC manual.
As it turns out B sources are common to LTspice and indeed there is a parameter "Rpar".
Take a look at LTwiki  http://ltwiki.org/index.php5?title=B_sources_(complete_reference)
For the current source, a parallel resistance may be specified with the Rpar instance parameter.
I found that capacitor models in LTspice also have "Rpar" parameter which defines parallel resistance.
So, I added parallel resistance between two same nodes and the model now seems to be working fine.
Barc arc A2 I= sgn(V(arc,A2))*uramp(abs(V(arc,A2))-V(ref))/(Rh*V(abn))
*Bref 0  ref  VALUE = {Vh+(Vs-Vh)/(1+V(ion)**2)} Rpar=1 ; voltage transition
Bref 0 ref I= Vh+{Vs-Vh}/(1+V(ion)**2) ; voltage transition
Rref 0 ref 1;
*Bion 0  ion  VALUE = {abs(I(Varc))} Rpar={1/Ii} ; measure of free ions
Bion 0 ion I= abs(I(Varc))  ; measure of free ions
Rion 0 ion {1/Ii};
*Babn 0  abn  VALUE = {Ia**2}+I(Varc)**2 Rpar={1/Ia**2} ; abnormal glow
Babn 0 abn I= {Ia**2}+I(Varc)**2 ; abnormal glow
Rabn 0 abn {1/Ia**2};
.ENDS NE-2H
What perplexes me is that it seems that MC accepts LTspice's B source "I" parameter but not "Rpar" and what
is even more curious is that I don't see B source mentioned in the MC reference guide.  Lips sealed
So, the first problem is solved.  Smiley
« Last Edit: May 22, 2017, 09:59:12 09:59 by LithiumOverdosE » Logged
optikon
-Given: 1113
-Receive: 2007
« Reply #3 on: May 22, 2017, 11:02:21 11:02 »
In MC, NFV or NFI seem to be the behavioral voltage and current sources. I am unsure which one follows the SPICE syntax more closely but yeah, clearly a difference.
LithiumOverdosE
-Given: 383
-Receive: 588
« Reply #4 on: May 22, 2017, 08:16:30 20:16 »
Indeed, but why is B source partially accepted by MC but not documented?
2. Back to TC4429 model problem.
First of all it seems that TC temperature parameter of few resistors is not in the form acceptable to MC.
As it turns out MC requires different syntax that includes equal sign and comma.
Example:
*R21 0 11 1 TC .3m 1.4u
R21 0 11 1 TC= .3m, 1.4u
Considering that MCHP explicitly says those are PSpice models I start to wonder to which extent MC is truly PSpice compatible. Lips sealed
So, that solved the problem with the resistors TC parameters.
Then MC threw error regarding extra parenthesis in the G source tables.
Well, it seems that MCHP have two missing parentheses in their model.  Sad
That was quickly fixed and the model is suppose to be running.
Here is the corrected model:
* Revision History:
* Recommendations:
* Supported:
* Not Supported:
*      Process variation
R1  4    1    2MEG
C1  4    1    38P
* Threshold
*R22 0 12  1 TC .1m -0.8U
R22 0 12  1 TC= .1m, -0.8U
C30 30   0    1n
* HL Circuit
*R31 31   0    1 TC 3.2M
R31 31   0    1 TC= 3.2M
* LH Circuit
*R32 0    32   1 TC 2.9M 10U
R32 0    32   1 TC= 2.9M, 10U
R30 32   30   1MEG
* DRIVE
*R53  0 50 1 TC -4m 12u
R53  0 50 1 TC= -4m, 12u
R51 51  0 1
R60 0    60   100MEG
H67 0    69   V67 1
V67 60   59   0V
C59 0    59   1.5N
C60 561    60   2N
R59 59   2   0.5
L59 59   2   5N
VC60        56 0 0V
RC60        56 561 1m
H60         58 0 VC60 56
* Source Output
*R63 0    63   1 TC 3.3M -2U
R63 0    63   1 TC= 3.3M,-2U
V63 65   3    10.0M
* Sink Output
*R64 0    64   1 TC 3.3M 6U
R64 0    64   1 TC= 3.3M, 6U
V64 66   4    10.0M
G62 60   62   TABLE {V(60,62)} ((-12.0M,-200.0)(-11.0M,-60)(-10.0M,-6)(0,0)(.1,5N)(10,10N))
* Bias Current
G55 0    55   TABLE {V(3,4)} ((0,0)(4,296U)(6,338U)(13,410U)(17,500U)(20,750U))
G56 3    4    55 0 1
*R55 55   0    1 TC  5.7M 19U
R55 55   0    1 TC=  5.7M, 19U
G57 0    57   TABLE {V(3,4)} ((0,0)(4.4,48U)(6,54U)(7,64U)(13,68U)(16,70U)(20,78U))
G58 3    4    57 0 1
*R57 57   0    1 TC  4.6M 49U
R57 57   0    1 TC=  4.6M, 49U
S59 55   0    1 0 SS59
* Models
.ENDS TC4429
However, although MC doesn't report any errors regarding the model, now I get singular matrix error. Huh
« Last Edit: May 22, 2017, 09:31:55 21:31 by LithiumOverdosE » Logged
LithiumOverdosE
-Given: 383
-Receive: 588
« Reply #5 on: May 22, 2017, 09:51:00 21:51 »
I have just noticed that the MC syntax for TABLE is differs from PSpice as well.
So, the corrected model is here:
*                    | Output
*                    Input
* soley and exclusively on Microchip products.                                 *
* Revision History:
* Recommendations:
* Supported:
* Not Supported:
*      Process variation
R1  4    1    2MEG
C1  4    1    38P
*G3  3    1    TABLE { V(3, 1) } ((-770M,-1.00)(-700M,-10.0M)(-630M,-10N)(0,0)(20.0,10N))
G3  3    1    TABLE { V(3, 1) } = (-770M,-1.00)(-700M,-10.0M)(-630M,-10N)(0,0)(20.0,10N)
*G4  1    4    TABLE { V(1, 4) } ((-5.94,-1.00)(-5.4,-10.0M)(-4.86,-10N)(0,0)(20.0,10N))
G4  1    4    TABLE { V(1, 4) } = (-5.94,-1.00)(-5.4,-10.0M)(-4.86,-10N)(0,0)(20.0,10N)
* Threshold
*G11 0    30    TABLE {V(1,11)}((-1m,10n)(0,0)(0.88,-.1)(1.5,-0.9)(2.2,-1)(4,-1.1)(6,-1.3))
G11 0    30    TABLE {V(1,11)} = (-1m,10n)(0,0)(0.88,-.1)(1.5,-0.9)(2.2,-1)(4,-1.1)(6,-1.3)
*G12 0    30    TABLE {V(1,12)}((-6,1.3)(-4,1.1)(-2.3,1)(-1.8,.9)(-0.7,.1)(0,0)(1,-10n))
G12 0    30    TABLE {V(1,12)}= (-6,1.3)(-4,1.1)(-2.3,1)(-1.8,.9)(-0.7,.1)(0,0)(1,-10n)
G21 0 11 TABLE { V(3, 4) } = (0,0)(4,1.34)(5,1.43)(6,1.5)(7,1.5)(10,1.48)(12,1.48)(18,1.5)
G22 0 12 TABLE { V(3, 4) } = (0,0)(4,1.16)(6,1.24)(7,1.24)(9,1.23)(11,1.23)(18,1.25)
C30 30   0    1n
* HL Circuit
G31 0    31   TABLE { V(3, 4) } = (0,75)(5,43)(5.5,39.5)(6,37)(7,34)(8,32)(12,29.2)(17,29.8)(18,28.6)
*R31 31   0    1 TC 3.2M
R31 31   0    1 TC= 3.2M
G33 0    30   TABLE { V(31, 30) } = (-1m,-10)(0,0)(1m,5n)(1,10n)
* LH Circuit
G32 32   0    TABLE { V(3, 4) } = (0,31)(5,19)(6,18)(8.5,15)(11.5,14.4)(17,15.5)(18,15.4)
G34 30   0    TABLE { V(30, 32) } = (-1m,-10)(0,0)(1m,5n)(1,10n)
R30 32   30   1MEG
* DRIVE
G51  0 50 TABLE {V(30, 0)} = (-5,-1n)(-3,-1n)(0,0)(5,6.8)(15,3.3)(30,4.5)
G52 50  0 TABLE {V(0, 30)} = (-5,-1n)(-3,-1n)(0,0)(4,6)(13,3.2)(15,3.0)(22,2.7)
R51 51  0 1
G53  3  0 TABLE {V(51,0)} = (-10,10)(0,0)(1,1n)
G54  0  4 TABLE {V(0,51)} = (-10,10)(0,0)(1,1n)
R60 0    60   100MEG
H67 0    69   V67 1
V67 60   59   0V
C59 0    59   1.5N
C60 561    60   2N
R59 59   2   0.5
L59 59   2   5N
VC60        56 0 0V
RC60        56 561 1m
H60         58 0 VC60 56
G60P 0 3 TABLE { V(58, 0) } = (-1,-1u)(0,0)(30,0.8)(100,1.3)
G60N 4 0 TABLE { V(0, 58) } = (-1,-1u)(0,0)(30,0.8)(100,1.3)
* Source Output
E67 67   0    TABLE {V(69, 0)} = (-10,-10)(0,0)(10,50)
V63 65   3    10.0M
G61 61   60   TABLE {V(61,60)} = (-12.0M,-200.0)(-11.0M,-60)(-10.0M,-6)(0,0)(.1,5N)(50,10N)
* Sink Output
E68 68   0    TABLE {V(69,0)} = (-50,-10)(0,0)(10,10)
V64 66   4    10.0M
G62 60   62   TABLE {V(60,62)} = (-12.0M,-200.0)(-11.0M,-60)(-10.0M,-6)(0,0)(.1,5N)(10,10N)
* Bias Current
G55 0    55   TABLE {V(3,4)} = (0,0)(4,296U)(6,338U)(13,410U)(17,500U)(20,750U)
G56 3    4    55 0 1
G57 0    57   TABLE {V(3,4)} = (0,0)(4.4,48U)(6,54U)(7,64U)(13,68U)(16,70U)(20,78U)
G58 3    4    57 0 1
S59 55   0    1 0 SS59
* Models
.ENDS TC4429
However "Matrix is singular" error persists.
I've raised relevant Spice parameters to the maximal reasonable level and the problem is still present.  Undecided
optikon
-Given: 1113
-Receive: 2007
« Reply #6 on: May 22, 2017, 10:49:25 22:49 »
Ive seen singular matrix errors before with Tables in G sources.. can you try commenting some of them out?
BTW, what characteristics are important for your driver model? The model seems rather complex (perhaps necessarily so)
Ive found that the tricky / important stuff for MOSFET drivers tends to not match very well in real world.. but YMMV of course.
LithiumOverdosE
-Given: 383
-Receive: 588
« Reply #7 on: May 24, 2017, 03:21:55 15:21 »
Actually, I have just removed the model from the test schematic, saved schematic and then added model back.
Now simulation works.  Undecided
Strange occurrences indeed.   Huh
2N5109
-Receive: 14
« Reply #8 on: June 23, 2017, 03:41:35 15:41 »
For what its worth here is LTSPICE's NE-2 model:
.subckt neonbulb 1 2
S1 1 2 2 N001 G
S2 2 1 N001 2 G
R1 1 N001 100Meg
C1 N001 2 {Tau/100Meg}
.model G SW(Ron={Zon} Roff=1T Vt={.5*(Vstrike+Vhold)} Vh={.5*(Vstrike-Vhold)} Vser={Vhold-Ihold*Zon})
.param Vstrike=100 Vhold=50 Zon=2K Ihold=200u Tau=100u
.ends neonbulb
To run this you probably need this info from LTSPICE help file:
S    Voltage Controlled Switch
Symbol Names: SW
Syntax: Sxxx n1 n2 nc+ nc- <model> [on,off]
Example:
S1 out 0 in 0 MySwitch
.model MySwitch SW(Ron=.1 Roff=1Meg Vt=0 Vh=-.5 Lser=10n Vser=.6)
The voltage between nodes nc+ and nc- controls the switch's impedance between nodes n1 and n2. A model card is required to define the behavior of the switch.
Voltage Controlled Switch Model Parameters:
Name   Description               Units  Default
Vt       Threshold voltage       V      0.
Vh       Hysteresis voltage      V      0.
Ron     On resistance             Ω     1.
Roff     Off resistance            Ω     1/Gmin
Lser     Series inductance       H      0.
Vser    Series voltage            V      0.
Ilimit    Current limit              A       Infin.
--2N5109
« Last Edit: June 26, 2017, 01:52:31 01:52 by 2N5109 » Logged
