November 24, 2024, 06:23:43 18:23
Author Topic: Panelizing PCB's - what do you use/recommend?  (Read 7493 times)
Sushilogic
-Given: 679
-Receive: 1017
« on: March 13, 2017, 12:48:44 12:48 »
I'm using KiCAD as an EDA tool at present, which doesn't have good support for panelization - if I was to migrate to Altium I guess that has it all built in, but for now I thought I'd like to find a 3rd party tool that will allow me to panelize designs.
I guess I'm looking for something that will allow me to :
1. Put multiple (different) designs on one small panel (custom size panels)
2. Use a combination of v-groove, slots, mouse bites to de-panel boards
3. Allow me to define the tooling strip and hole size/location
4. Allow me to add fidicials
Seem to be a number of options out there though some appear to have steep learning curves :
FAB 3000
CAM350
VisualCAM
GerbTool
CAMMaster Designer
etc
What do you use/recommend?
Cheers Smiley
mars01
-Given: 697
-Receive: 1774
« Reply #1 on: March 13, 2017, 02:36:37 14:36 »
I don't have much experience using those tools, I also am gathering info about this.
From the hobby point of view I can tell you what I do.
There are 2 methods that I use when I want to do panelization.
1. I make the design and export the GERBER + EXCELLON files. Those I open using FlatCAM http://www.flatcam.org/download using the development version.
It has a panelize command (it has to be run from command line, the program has a TCL shell). You can do this after you generate the cutout geometry.
Unfortunately it can't export GERBER files, only GCODE, so if you have a CNC router and you make your own PCB's (like I do) this is an efficient way to do just that.
2. I make the design and export the GERBER + EXCELLON files in a software of my choice. I import the Gerber files in the small program Sprint Layout (we have medicine here: http://www.sonsivri.to/forum/index.php?topic=9657.0) and there I can make the panelization very easy - just copy and  paste operations, I also can export the panelized GERBER's and EXCELLON (drill) files. This software allow you to print the negative film (in case you are using UV method to make your PCB's).
Fiducial are just components that need to be placed in a certain way. You can make your own.
See this very complete post: http://www.eevblog.com/forum/altium/fiducials/msg103904/#msg103904
« Last Edit: March 13, 2017, 02:56:26 14:56 by mars01 » Logged
-Given: 231
-Receive: 983
« Reply #2 on: March 13, 2017, 02:56:29 14:56 »
You will find a lot of how to videos on YouTube for any of these tools. Like always some will be good other may be bad. But doing some search will be a good idea
optikon
-Given: 1106
-Receive: 2007
« Reply #3 on: March 13, 2017, 05:09:12 17:09 »
I recommend CAM350 - it can do everything you need to.
bigtoy
-Given: 337
-Receive: 297
« Reply #4 on: March 15, 2017, 09:27:34 21:27 »
I've done a couple of panels.
Typically I find it easiest to do the panelization inside of a PCB program. That's because you usually want to add features to the panel (like tooling holes, house bites, silkscreen labels, etc). In Altium there are a couple of ways of doing it. The main way is to use the built-in panelization tool. Described here:
http://techdocs.altium.com/display/ADOH/((Panelization+-+Embedded+Board+Array+Enhancements))_AD
If you've got a number of different PCBs you want to incorporate into the same panel, it can be easier to just (a) create a blank PCB document for your panel, (b) copy & paste your PCB layouts (remember to turn on all used layers) into the new PCB document.
Cyberrat
-Given: 567
-Receive: 128
« Reply #5 on: April 21, 2017, 06:54:22 06:54 »
Just a note, if you panelize a single design yourself, guess what happens at the front end engineers desk of the fab house.
They strip off all your panelized boards leaving a single image, do their drc checks, adjustments, fixes etc. and then re panelize it.
So your wasting your time, its better to do a panel drawing and send a single image.
optikon
-Given: 1106
-Receive: 2007
« Reply #6 on: April 21, 2017, 10:05:38 22:05 »
You are correct about this. It's probably best to leave it up to them anyways.
kayvee
-Given: 98
-Receive: 101
« Reply #7 on: April 22, 2017, 06:07:42 06:07 »
Normally I draw my desired panel layout on a separate layer and submit with all the other layers.
M@X77
-Given: 46
« Reply #8 on: May 05, 2017, 10:21:47 10:21 »
I use always eagle, simply execute ULP script named "panelize.ulp", this create 3 layers with the components name, the you hide the original components name layer (tnames and bnames). Create a group of the board and copy it each times you need.
GroundPlaneLoop
« Reply #9 on: September 08, 2017, 07:59:44 19:59 »
I would reccomend GerbTool. Some details are easier in CAM350, but usually GerbTool is a great tool to panelize. You only have to learn and accept the somewhat unusal handling (the selection of anything is not very intuitive, but after you learn it to use, it is very logical - you select first the action - copy, move, delete, then you set the selection filter - window, one item etc...)
But almost any PCB producer will panelize the design according to their technology. They can have special requirements about the milling, the bridges which you leave to hold the PCB in the panel and so on. I think it is better to let them to do it. Its usually free, or for a very small surcharge, and its worth it, the hassle with DIY panelization is not worth the time you spent with it, and the manufacturer can tell you that your panel is not acceptable due to technology limits.
« Last Edit: September 08, 2017, 08:02:45 20:02 by GroundPlaneLoop » Logged
conanmayer
 Warned
-Given: 17
« Reply #10 on: September 09, 2017, 02:55:00 14:55 »
I use VisualCAM/GerbTool.
PICker
-Given: 207
-Receive: 110
« Reply #11 on: September 09, 2017, 09:19:35 21:19 »
I do not know if frontdesigner from abacom may be useful for your aim:
http://www.abacom-online.de/uk/html/frontdesigner.html
mars01
-Given: 697
-Receive: 1774
« Reply #12 on: September 09, 2017, 10:46:30 22:46 »
@PICker, front designer from Abacom is a software for making illustration of a front panel for an enclosure.
The topic here is about placing multiple PCB patterns (either multiple design's or same design multiplied) on a single big board.
PICker
-Given: 207
-Receive: 110
« Reply #13 on: September 10, 2017, 12:52:26 12:52 »
@mars01, I'm very sorry for misunderstanding.
