April 18, 2026, 10:31:16 10:31
Author Topic: How to plot an object boundary using MATLAB if we have coordinate x,y,z  (Read 4971 times)
xpress_embedo
-Given: 122
-Receive: 254
« on: December 09, 2016, 11:47:38 11:47 »
Hello! Everyone, I have Object placed inside a box and i used distance sensors to get the distance of the object from a reference point (0,0,0), now i want to plot the surface of this object using MATLAB, but i am confused, which plotting function to use.
Suppose the object placed is cylindrical object as shown below.
These are the valid points which i get from the sensor from point (0,0,0) and all of these points are same across the z-axis
x = (89.26772163,89.2251516,89.17737906,89.05573047, 88.8611554,88.59463961,88.2572044,87.84990611, 90.60990337,93.38333305,96.16835842,98.96312702, 101.7657715,104.5744107,107.4709263)
y = (86.20483673,83.20379993,80.29567276,77.41496542, 74.56336272,71.74252458,68.95408524,66.19965255, 65.83194826,65.38771374,64.8663768,64.26740613, 63.59031171,62.83464514,62.04836823)
How can i plot using these points to get the image as follow:
With the points above, it is not possible to draw the complete image, but at-least it is possible to draw the boundary of the front side. Please suggest which type of plot, surface plot i can use.
« Reply #1 on: December 11, 2016, 12:00:39 00:00 »
Assuming those distances are in meters, the 10nm sensor resolution you have there is so impressive you should share with us what it is.
PhD?
xpress_embedo
-Given: 122
-Receive: 254
« Reply #2 on: December 25, 2016, 05:57:57 05:57 »
PhD?
Sorry for late reply.
These points are manually calculated (Using Excel) and there is no such sensor.
The Project which i am working on is Object Shape Recognition without Camera, and it is divided into two parts, one uses sensor (Laser/IR as distance sensor) which scans the distance of the object in 3 dimensions and send these values to PC, and second part is to use these points and plot the boundary of the Object.
Something like 3D scanner, but object is stationary in this case and sensor will rotate.
So i am working on second part and that's why i manually taken a use case and with the help of excel i developed some points and used that for plotting.
