Hello dear members,
I am trying to implement an adc simulation using proteus-labview. The program logic is that, dsPIC converts adcData as unsigned 16-bit integer and send it with 115200 baud. Input signal is sinusoidal with 1 hz. When I programmed PIC16f, 18f series, I was trying to simulation before realizing circuit physically. But in this dsPIC simulation, some adc values jumps randomly. So I could not solve the problem for hours. The situation did not change in either manual or auto sampling-conversion modes. I have almost read all of related adc documents of microchip and I coded it bit by bit. Here is my setupADC function:
void ADC_Init(void)
//12bit conversion
AD1CON1bits.AD12B = 1;
//voltage references
//000: AVdd,AVss
//001: +VREF,AVss
//011: +VREF,-Vref
AD1CON2bits.VCFG0 = 0;
AD1CON2bits.VCFG1 = 0;
//select conversion clock freq
//111111: 64Tcy, for 40MHZ Oscillator
//for int osc, dont touch these bits
AD1CON3bits.ADCS0 = 1;
AD1CON3bits.ADCS1 = 1;
AD1CON3bits.ADCS2 = 1;
AD1CON3bits.ADCS3 = 1;
AD1CON3bits.ADCS4 = 1;
AD1CON3bits.ADCS5 = 1;
AD1CON3bits.ADCS6 = 0;
AD1CON3bits.ADCS7 = 0;
//AN0 analog
AD1PCFGLbits.PCFG0 = 0;
TRISAbits.TRISA0 = 1;
//positive input an0 for ch0
AD1CHS0bits.CH0SA0 = 0;
AD1CHS0bits.CH0SA1 = 0;
AD1CHS0bits.CH0SA2 = 0;
AD1CHS0bits.CH0SA3 = 0;
AD1CHS0bits.CH0SA4 = 0;
AD1CHS0bits.CH0SB0 = 0;
AD1CHS0bits.CH0SB1 = 0;
AD1CHS0bits.CH0SB2 = 0;
AD1CHS0bits.CH0SB3 = 0;
AD1CHS0bits.CH0SB4 = 0;
//just ch0 will do conversion
//dont touch this for 12bit conversion
//12 bit conversion just can be done with ch0
//AD1CON2<9:8>
AD1CON2bits.CHPS = 0;
//7. step
//select manuel or auto sampling
//000 0 manual sampling manual conversion
//111 1 auto
AD1CON1bits.SSRC0 = 1;
AD1CON1bits.SSRC1 = 1;
AD1CON1bits.SSRC2 = 1;
AD1CON1bits.ASAM = 1;
//sample time setting for auto sample
//this is not important for manual sampling
AD1CON3bits.SAMC0 = 1;
AD1CON3bits.SAMC1 = 0;
AD1CON3bits.SAMC2 = 0;
AD1CON3bits.SAMC3 = 1;
AD1CON3bits.SAMC4 = 1;
//clock source select bit
//internal RC
//internal rc for dsPIC33fj32MC204 is 4MHZ
AD1CON3bits.ADRC = 0;
//select result format
//For 12-bit operation:
//10 = unsigned Fractional (DOUT = dddd dddd dddd 0000)
//00 = unsigned Integer (DOUT = 0000 dddd dddd dddd)
//11 = signed fractional
//01 = signed integer
AD1CON1bits.FORM0 = 0;
AD1CON1bits.FORM1 = 0;
//sample number per interrupt
//1111 = 16 sample for an interrupt
//0000 = 1 sample for an interrupt
AD1CON2bits.SMPI0 = 0;
AD1CON2bits.SMPI1 = 0;
AD1CON2bits.SMPI2 = 0;
AD1CON2bits.SMPI3 = 0;
//configure interrupt
//no nested interrupt
INTCON1bits.NSTDIS = 0;
//clear interrupt flag
IFS0bits.AD1IF = 0;
//interrupt is priority 7
IPC3bits.AD1IP0 = 1;
IPC3bits.AD1IP1 = 1;
IPC3bits.AD1IP2 = 1;
//ADC1 Conversion Complete Interrupt Enable bit
IEC0bits.AD1IE = 0;
//adc module enable
AD1CON1bits.ADON = 1;
this is the task which runs in while(1) loop in main function:
AD1CON1bits.SAMP = 1; // Start sampling
for(i=0;i<5000;i++)// Wait for sampling time (a little time)
Nop();
AD1CON1bits.SAMP = 0; // Start the conversion
while (!AD1CON1bits.DONE); // Wait for the conversion to complete
sendData.sendData = ADC1BUF0; // Read the conversion result, this is unsigned int union type
U1TXREG = sendData.bytes[0];
while(!U1STAbits.TRMT);
U1TXREG = sendData.bytes[1];
U1TXREG = '\n';
Also I attached an image that shows the situation.
Note: I know proteus is not real but it worked all the time with 16f and 18f series.
EDİT:I solved the problem, dear members. If someone have same issue, that person should make false the "termination char" parameter on the open visa variable at the labview side.
Thanks.
