November 26, 2024, 06:37:23 18:37
Author Topic: STM32F103C8T6 USB HID problem  (Read 4493 times)
Kombinator
-Given: 39
-Receive: 32
« on: August 06, 2016, 11:49:28 11:49 »
Hello
I trying to set up a USB HID STM32F103C8 board. Use MicroC ARM 4.9.0 and TOP's MED18.
I use the example of Mikroelektronika Help site with USBdsc.c generated file Аfter compilation
PC says "USB Device  not Recognized".
SYSCLK is correct. A8 PIN have 36MHz. Waveforms of USB D + and D- look good.
USB communication with other project works well.
Is it possible to receive compiled BIN file from another microC ARM with real license .
Or working project MikroC ARM with this processor and usb HID
Attach generated BIN and HEX file.
Code is here:
 //void USB1Interrupt() {
 // USB_Interrupt_Proc();
unsigned long int i = 0;
char cnt;
char kk;
char readbuff[64];
char writebuff[64];
void main() {
GPIO_Config(&GPIOA_BASE, _GPIO_PINMASK_8, (_GPIO_CFG_MODE_ALT_FUNCTION | _GPIO_CFG_SPEED_50MHZ | _GPIO_CFG_OTYPE_PP));  //Set PA8 as a high speed digital output
  HID_Enable(&readbuff,&writebuff);
  while(1){
  USB_Polling_Proc();      // Call this routine periodically
    kk =HID_Read();
    if(kk != 0){
      for(cnt=0;cnt<64;cnt++);
        writebuff[cnt]=readbuff[cnt];
     HID_Write(&writebuff,64);
STM32CubeMX   The configuration is correct
Settings configuration file of the project is as STM32CubeMX .
« Last Edit: August 08, 2016, 10:03:23 10:03 by Kombinator » Logged
Kombinator
-Given: 39
-Receive: 32
« Reply #1 on: August 06, 2016, 04:34:30 16:34 »
Problem is :
const char USB_INTERRUPT = 1; // in descriptor file must by 0;
Completely incomprehensible to me   must be declared, not used in mine(); Without the i variable does not work HID_Read();
TOP's MED18 It works well with USB and limit code
« Last Edit: August 07, 2016, 09:11:41 09:11 by Kombinator » Logged
