November 29, 2024, 12:35:35 00:35
Author Topic: [Req] 12kW, 5KV Capacitor Charging Power supply design Help  (Read 4799 times)
itp
-Given: 224
-Receive: 20
« on: July 30, 2016, 05:51:24 17:51 »
Hi All,
I have to design and develop a 12kW, 5 KV Capacitor Charging Power supply for a client. A resonant converter topology is preferable. Experience persons Kindly suggest tutorials/links/simulation software etc.
Thanks and regards
Itp
« Last Edit: July 31, 2016, 11:55:53 11:55 by itp » Logged
medik
-Given: 75
« Reply #1 on: August 08, 2016, 06:21:43 06:21 »
I have seen a boost dc dc converter of 12kW at 400V 30A Max. From your requirements less than 3A is needed.
 I advise that you build a scaled down version of say 500W before going to experiment with high 12kW.
You did not state the input voltage source and level. Is it going to run off batteries?
« Last Edit: August 08, 2016, 06:24:31 06:24 by medik » Logged
itp
-Given: 224
-Receive: 20
« Reply #2 on: August 08, 2016, 03:56:11 15:56 »
Hi medik,
It will be operated from three-phase (420V) supply.
itp
roscoe
« Reply #3 on: October 01, 2016, 01:27:55 01:27 »
There are a few approaches that could work here -- you could use something like a SEPIC style boost w/ a transformer and then a ladder multiplier.  You probably don't care *too* much about ripple since you're just charging caps.  The downside is that it will take a while to charge them like this.
Alternatively, you could look for an IGBT and switch rectified voltage.
« Reply #4 on: October 05, 2016, 11:57:05 23:57 »
I've built these before.  The best design is resonant as you suggest so you can take advantage of high queue to get the MANY X boost you need.  This is NOT a trivial design.
The last time I did it was 15KW from 208V 3  phase input for 800V output, open circuit however it was 5000V.
A trick you can use with LLC is that you can get both Ls in one leakly solenoid (leakage inductance makes one L and magetizing inductance makes the other)  full bridge IGBT resonant 100KHz to 500KHz worked out well for us.
It was a beast of a design and cost about $1m to develop.  Granted it had a graphical UI, industrial comm protocols, 1% measurement and accuracy, and could survive high frequency plasma arcs on the output (very low stored energy output).
I hope you are a VERY experienced power designer.  This is NOT an easy design.
Also be careful of corona, you will have a problem with it on the edges of traces of our PCB outer layers.
itp
-Given: 224
-Receive: 20
« Reply #5 on: October 07, 2016, 08:30:14 08:30 »
Hi all,
Can you suggest any published journal papers on this topic. Searching on google will definitely fetch lot of results. But I would rather prefer Experts in this field suggest some relevant papers.
Thanks and regards
Itp
Sat
-Given: 38
-Receive: 40
« Reply #6 on: October 07, 2016, 12:06:25 12:06 »
Hi Itp,
Use two stage power conversion for your application (AC to DC front end converter for 420Vac to 800 VDC conversion. A ZVS phase shifted interleaved fullbridge for 800VDC to 5KVDC)
Try  VIENNA rectifier for front end converter purpose.
https://en.wikipedia.org/wiki/Vienna_rectifier
Use multiple outputs in fullbridge (8 outputs, each output voltage is 625V). After rectification add all these outputs in series connection to get 5KV.
i hope your are expert in power electronics design, because it is very tough requirement. I suggest to you initially make a scale down (1.2KW) prototype.
Thanks,
Sat
2N5109
-Receive: 14
« Reply #7 on: December 09, 2016, 02:53:12 02:53 »
Here is a useful link for you:
 https://files.acrobat.com/a/preview/d3aeb95b-8d7d-4f26-a078-6dbf721e8f1d
Good luck, 5kv is not so bad. I have built 10kv pulse power frozen wave generators with careful lab procedures.
--2N5109
Diramo
-Given: 450
-Receive: 54
« Reply #8 on: December 21, 2016, 08:41:11 08:41 »
Hi. Ten years ago I built power pulse generator with hydrogen thyratron, the average output power was 10KW, pulse voltage 25KV.
I used resonant bridge converter for pulse forming network charging. My design was based on the publication, attached below.
« Last Edit: December 21, 2016, 08:44:41 08:44 by Diramo » Logged
