July 02, 2024, 05:49:34 17:49
Author Topic: RTC ds1306  (Read 5507 times)
hristofor
« on: November 07, 2007, 12:50:15 12:50 »
enybody work with ds1306 - picbasic ?
I need some example.
leemarrow
Online Online
-Given: 317
-Receive: 52
« Reply #1 on: November 07, 2007, 01:17:10 13:17 »
hi,
try this for ds1307
http://www.melabs.com/resources/samples/submitted/MN1307.txt
savnik20
-Given: 37
-Receive: 401
« Reply #2 on: November 07, 2007, 02:05:35 14:05 »
The best fro Melanie
donno
« Reply #3 on: November 08, 2007, 02:46:27 14:46 »
hi, more code snippets picbasic i2c and DS1307 at...
http://www.mikroe.com/forum/viewtopic.php?p=15622&sid=6eb218da120422b66a251c02bd981e44
http://blog.faludi.com/category/advanced-microcontrollers/
Time and Temperature at...
http://www.rentron.com/PicBasic/SERLED.htm
or C
http://www.techdesign.be/projects/routines/ds1307_void_a.htm
http://www.best-microcontroller-projects.com/real-time-clock-ic.html
Hope this helps!
donno
« Reply #4 on: November 08, 2007, 02:51:59 14:51 »
Sorry forgot this one... a good guide...
http://users.picbasic.org/index.php?page=howtodetail&id=53
ciao
fernandodiaz
« Reply #5 on: November 10, 2007, 10:00:52 22:00 »
Include "PROTON_4.INC"
   Dim W0   as   Word                          ' Address
   Dim B1   as   byte
        dim B2  as  byte                         ' Data 1
        dim B3  as  byte
        dim B4  AS  BYTE
        DIM B5  AS  BYTE
        DIM B6  AS  BYTE
        DIM B7  AS  BYTE
               dim  temp as byte
 '  for read
   loop:
   print at 1,1,"              "
   print at 2,1,"              "
CONVIERTEIN: ' DEC A HEX
TEM = ((TEM >> 4) * 10)+ TEM & $0F) 'DEC A HEX PARA GUARDAR AL CHIP
Return
                          ' Data 2
BUSIN 208,0,[b1] ' seg poner temp por b1
BUSIN 208,1,[b2] ' min
BUSIN 208,2,[b3] ' hrs
BUSIN 208,4,[b5] ' dia
BUSIN 208,5,[b6] ' mes
BUSIN 208,6,[b7] ' año
' BUSIN $D1,0,[SEC] ' seconds, if yo read this address the RTC stop the count.
            Print at 1,1,hex b3 ,":",hex b2,":",hex b1
            Print at 2,1,hex b5 ,":",hex b6 ,":",hex B7
            Delayms 500
   '___________________________________________________________________________________________-
'for write
       if portb.0 = 1  then
        temp = 10
        temp = ((temp / 10) << 4) + (temp // 10) :  busout 208,4,[temp]  ' conv  decial a  hex
        temp = 10
        temp = ((temp / 10) << 4) + (temp // 10) :  busout 208,5,[temp]   ' conv  decial a  hex
               temp = 10
        temp = ((temp / 10) << 4) + (temp // 10) :  busout 208,6,[temp]   ' conv  decial a  hex
       endif
        Goto loop
' suerte
raraavis
-Receive: 12
Buenos Aires - Argentina
« Reply #6 on: November 11, 2007, 04:22:35 04:22 »
Proton and ds 1307
