November 26, 2024, 12:37:17 12:37
Author Topic: Need - Fanuc perforated paper Tape Reader Schematic  (Read 4221 times)
Matrixx
-Given: 68
-Receive: 37
« on: July 09, 2016, 09:14:33 21:14 »
I'm looking for a Fanuc perforated paper Tape Reader schematic. I'm in he process to build an BTR circuit, but would like to well understand the tape reader PCB circuitry before. I have started drawing by hand; removed almost all the IC's to have good tracks view. There is some 6 pin resistor network chips that I didn't find, and looks is two separated resistor circuits as the ohm reading are kind odd.
The goal is to build a Beyond Tape Reader interface for a Fanuc 6M controller, using an Atmega uC.
The tape reader is :     A13B-0070-B001
The tape reader PCB:   A20B-0007-0750/07B
The resistor network below is 6 pin. Pins #5 & #6 looks to be a single resistor 17k, but pins #1 to #4 could be some sort of bridge resistor circuit as the ohm readings are not normal.
Hope someone have the tape reader schematic, to compare. I will upload mine when I finish to trace all the circuits.
Im mostly interested on the 50 pin connector signaling.
« Last Edit: July 09, 2016, 09:24:12 21:24 by Matrixx » Logged
