November 29, 2024, 04:45:27 04:45
Author Topic: You only need two things in life  (Read 5029 times)
xeontory
-Receive: 41
« on: May 16, 2016, 10:22:23 22:22 »
Some of you have already seen some of these. The leaflet advertising of WD-40 lubricant from the 1960's. Loaded with double entender when it was first marketed. Now it says:
“You only need two things in life: Duct Tape and WD-40. If it moves and shouldn’t, use Duct Tape, if it doesn’t move and should, use WD-40.”
« Last Edit: May 16, 2016, 10:41:12 22:41 by xeontory » Logged
Checksum8
-Given: 124
-Receive: 102
« Reply #1 on: May 17, 2016, 03:53:00 15:53 »
This is also good on those cold days!
« Last Edit: May 17, 2016, 03:55:39 15:55 by Checksum8 » Logged
crunx
« Reply #2 on: May 21, 2016, 07:26:02 19:26 »
Even if that WD-40 ad is pretty cool, it is likely a hoax. See for instance:
http://www.snopes.com/photos/advertisements/wd40ad.asp
Any way, it is hilarious. Therefore thanks for presenting it!
Signal
-Given: 113
-Receive: 81
« Reply #3 on: May 23, 2016, 06:00:14 06:00 »
This sentence reminds me the similar one about two reasons of failures in electronics - there is a contact where it should not be or there is no contact where it should be. something like that.
« Reply #4 on: May 23, 2016, 02:12:36 14:12 »
What a nice oversimplification.  That's like when people say "software should be easy, it's just ones and zeros, one or the other, what's so complicated"
