November 25, 2024, 10:46:59 10:46
Author Topic: Altium 3D value render  (Read 4197 times)
MAXPAYNE
-Given: 499
-Receive: 364
It's a little funny......
« on: January 20, 2016, 08:46:10 08:46 »
How to render resister value in Altium 3d as shown below ?
koky
-Receive: 157
« Reply #1 on: January 20, 2016, 09:06:24 09:06 »
press Key 3
for have also text value different, you must make a stp 3d file for each resistor value
« Last Edit: January 20, 2016, 09:09:13 09:09 by koky » Logged
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #2 on: January 20, 2016, 09:07:36 09:07 »
press Key 3
Actually I was asking the way to put value on the top in 3D view.
bigtoy
-Given: 337
-Receive: 297
« Reply #3 on: January 26, 2016, 05:14:23 05:14 »
What koky said. There's no magic way. You need to draw that text in the 3D model. So for every different resistor value you would need to manually create & store a different 3D model.
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #4 on: January 26, 2016, 05:18:56 05:18 »
Yap. I came to know its not possible. SO I am doing things manually.
« Reply #5 on: January 27, 2016, 03:21:45 03:21 »
I avoid using step models in my libraries and only uses the simple altium extrusions.
Once the library gets slightly big the step files take up WAY too much space.  library and PCB files become huge.  I don't like it.
bigtoy
-Given: 337
-Receive: 297
« Reply #6 on: February 01, 2016, 12:44:26 00:44 »
We use Altium at work, and we have step file models in all of our library components. Including more "complicated" components (mechanically complicated anyway) like switches, connectors, etc. Our libraries are literally many hundreds of MBs in size. They are quite slow to load.
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #7 on: February 01, 2016, 06:11:41 06:11 »
Well, if you want something extra you have to sacrifice something also ! Smiley
mexpcb
-Given: 35
-Receive: 211
« Reply #8 on: February 04, 2016, 12:00:30 00:00 »
it may be easier to add texture on 3D..
search for "video-pcb-texture-mapping"
