April 14, 2026, 10:44:23 22:44
Author Topic: GUI Windows Bootloader Available with code.  (Read 7120 times)
jcddcjjcd
« on: October 28, 2015, 02:16:35 02:16 »
I recently wanted to test out the dsPIC33FFJ128MC802 and when I started to like it I also wrote a Windows Bootloader to compliment what I was doing. It is written in C#.
I have posted it at http://www.microchip.com/forums/m893364.aspx
The details are all there and the C# Project as well as a slightly modified target side bootloader and a Breadboard demo project that I used to verify everything as well as try a couple of things on the dsPIC33F.
John.
« Reply #1 on: October 28, 2015, 02:53:20 14:53 »
Which microchip bootloader that you refer to?
jcddcjjcd
« Reply #2 on: October 28, 2015, 09:00:28 21:00 »
Ichan.
The Bootloader is for XC16 bootloaders on dsPIC33F devices. I have writen it to support the dsPIC33FJ128MC802 but writen the C# code to make it easy for C# coders to add devices or Families.
I made it so that it uses the Microchip supplied bootloader on the target side. This makes it easy to implement and test.
If you go to the link I supplies you will see a fuller description.
John.
« Reply #3 on: November 02, 2015, 06:54:20 18:54 »
Download it and check it briefly, it is serial bootloader - i prefer usb, but still good work and thanks.
Anyway what version of Visual Studio it is? Mine can not open it (still 2010).
jcddcjjcd
« Reply #4 on: November 03, 2015, 03:03:14 03:03 »
I am using the now free Visual Studio 2015 Comunity Edition.
John.
charlie23
« Reply #5 on: November 25, 2015, 01:14:46 13:14 »
I developed in .net years ago and I remembered when Visual Studio 2010 came out I tried it but I didn't like it so I downgraded to the 2008 edition but some of my projects weren't compatible so changing some value (I don't remember what was that I left VS in 2012, but I think it was some that is named ToolVersion or something like it ) in the .csproj file made it to work on 2008 without problems.
