November 24, 2024, 12:39:45 00:39
Author Topic: High-frequency ground separation  (Read 3714 times)
intel
-Given: 53
-Receive: 2142
« on: September 25, 2015, 02:44:12 14:44 »
Hello friends. I use a card to modernize the circuit, I share with you. 1/1 transformer was working with the old card. Over time they become irreparable. This card works stable even in nanoseconds. (Minimum 9 nanosecond). It can be used in your ground separation process. For example, the Ethernet switch or power control circuits can be used for safe operation. I try to help if you have questions. Good work.
« Reply #1 on: September 28, 2015, 05:25:07 05:25 »
What opto is that you're using?
intel
-Given: 53
-Receive: 2142
« Reply #2 on: September 28, 2015, 05:52:41 05:52 »
6N137
http://www.vishay.com/docs/84732/6n137.pdf
« Reply #3 on: September 28, 2015, 07:20:20 07:20 »
You'd never make it in production running it on a 9 nsec bit clock.
For a one off, buying the same date code, sure.
intel
-Given: 53
-Receive: 2142
« Reply #4 on: September 28, 2015, 07:46:30 07:46 »
Final decision for what you try. I was in the workshop, using pulse generators and oscilloscopes and trying wrote. If you want to try before.
