quqnuss
« on: November 01, 2007, 05:42:53 17:42 » |
hello everyone,
first of all, because I couldn'st search in the forum that's why I am opening this topic .. so if it exist already, let me know and delete this topic.
I am told to build communication network among controllers. Coumputers could also be included, but if then in future, so computer inclusion is not that important right now.
can anyone write his/her experience about using CAN or RS485 as communication protocol ? which one is better and why ? any practical example schematic/project ?
regards.
chrisdodge
-Receive: 15
« Reply #1 on: November 01, 2007, 07:59:12 19:59 » |
RS485 is only a "physical" protocol ... it offers only data transport ... Easy to use, easy to hardware implement (just put RS485 differencial driver behind your PC or µC uart output.
CAN is far better than RS232/RS485 : - multimaster protocol - hardware CRC data error checking and recovering - hardware auto Retry - faster
But a lot of overhead .... 80 bits of payload out of 128 bits packet !
phamthaihoa
-Given: 8
« Reply #2 on: November 01, 2007, 08:07:05 20:07 » |
hello everyone,
regards.
You can find sample project and schematic in www.mikroe.com
Lumos
-Given: 73
« Reply #3 on: November 02, 2007, 05:39:05 05:39 » |
hi, My Homeautomation, I have control with RS485 built. 1 Master (18F252) and 10 slaves (18F4433,16F628...) to work without problems. Very easy handling Programmed in Proton Basic.
mcr
-Given: 217
-Receive: 23
« Reply #4 on: November 02, 2007, 07:05:52 07:05 » |
RS485 is your choice. RS485 is only a "physical" protocol ... it offers only data transport ... CAN is far better than RS232/RS485
To use CAN, you should understand first how the info is transmited and received, the physical layer: the protocol. If your assigment (looks like you're in school) is to just communicate devices, RS485 is your choice; you still have to document yourself on the protocol to see the implementation of it. Go to http://www.bb-elec.com/tech_articles/rs422_485_app_note/table_of_contents.asp for the info.
Ret12_12
-Given: 104
-Receive: 32
« Reply #5 on: November 02, 2007, 06:12:06 18:12 » |
Hi, Whats happed in case if 2 or more slave try to transmitted at the same time ? Can you please share the code when transmit and when receive ?
micro_tools
« Reply #6 on: November 02, 2007, 08:17:14 20:17 » |
1) rs 485 network is typicali one master and many slave 2) on CAN bus collision is handled at hardware level
Best regards micro_tools
mcr
-Given: 217
-Receive: 23
« Reply #7 on: November 02, 2007, 10:08:13 22:08 » |
Read this: http://www.bb-elec.com/tech_articles/rs422_485_app_note/table_of_contents.asp Can you please share the code when transmit and when receive ?
If you read the application note you'll notice the lack of "code" of this protocol. If you want code you must define what is it that you want to communicate, and with what. Please, read the application note.
Lumos
-Given: 73
« Reply #8 on: November 03, 2007, 10:47:17 10:47 » |
Hi Ret12_12
Already in the program, it is excluded, which is 2 slaves report
mana111
« Reply #9 on: November 04, 2007, 12:15:15 12:15 » |
Hi Ret12_12
Can you please upload the circuits also??
Lumos
-Given: 73
« Reply #10 on: November 05, 2007, 08:43:22 08:43 » |
Hi mana111
I do not, so what if you can start. Is specially tailored to me. Very properly, it is also not, but see themselves
microled
-Given: 15
« Reply #11 on: November 20, 2007, 09:56:57 21:56 » |
485 is easier to use and implement can lots of overhead harder to implement but much more powerful
piclover
-Given: 27
-Receive: 98
« Reply #12 on: November 22, 2007, 12:19:29 12:19 » |
I have expirience with RS485: PIC16F877A as a master and on other side PIC16F876A as a slave. Speed is 115200 b/s. As converter is SN75176. No problem at all
Math
« Reply #13 on: November 22, 2007, 09:34:03 21:34 » |
RS485 or CAN, it really depends on the application where you wanna use it. If you want to make a apllication with cars it would be the best to use CAN, but in your case I would prefer RS485.
jorge7458
-Receive: 14
« Reply #14 on: November 26, 2007, 05:54:58 17:54 » |
Hello a quite common confusion exists: DOG is a protocol that defines the message (bit,bps,crc,etc) and 485 are an electric norm, you cannot compare one with other. - It is as comparing RS232 with MODBUS. - I wait they have understood each other Jorge
micropar
-Given: 44
« Reply #15 on: November 26, 2007, 06:32:50 18:32 » |
hi all,
RS-485 is very low level embedded micro's network, but easy to implement with 9 bit Master-slave protocol, first implemented by our Father of Micros, Intel, as Bitbus in 70s.
CAN is robust protocol with its own hardware standard and automatic error detections, originated in 90s by BOSCH for in car communication, but needs upper level application support or firmware library such as CAN-Open or CAN-Kingdom for its full and efficient utilization.
Is any one has ready made source codes for above 485 and CAN to try with PICmicros?
Thanks in advance,
Regards, --micropar--
yoda
-Given: 706
« Reply #16 on: December 14, 2007, 05:28:34 17:28 » |
Hi quqnuss ,
You should choose RS485, CAN is to much overhead for your need (if you want to communicate between microcontrollers). If you make one station the master, and give all the other ones a name as slave (slav01. slav02 and so on) you can setup a simple network by letting anyone talk to the master only, and only if they are requested to, by the master. The master distributes all the data then. You can program this for a normal serial output but then convert it to RS485 (with a MAX485 ic) to get balanced lines. These 2x 2 balanced lines should be distributed to all stations (several hundred meters max.), including a ground or return line to be secure. On the software side you only have to resolve the problem that only one station at the time is transmitting (all others are listening). This can be arranged because only the master takes initiatives (by polling the slaves sequencially), the slaves only answer if they recoqnise their own name. Good luck.
p.s. I have in the past, transfered data over 19 Km distance this way, using rented ordinary tel. lines, and a baudrate low enough.
« Last Edit: August 01, 2008, 09:38:38 09:38 by yoda »
benco
« Reply #17 on: May 02, 2008, 10:08:14 22:08 » |
We had some job in the fabric and two computers communicated with RS485 on 700 meters /shield cable 4x1 cuprum/
