November 28, 2024, 07:49:12 07:49
Author Topic: usbasp programmer  (Read 4665 times)
abdullahshawky
-Given: 8
-Receive: 19
« on: July 02, 2015, 10:32:31 10:32 »
hi guys ,
i used to manifacture my programers using usbasp and it worked fine on all windows versions
now i decided to buy ready made chinese version ( which looks like flash drive)
it is installed automatically on windows (all versions on many computers) as an HID device , my old Khazama programming software cant find a programmer while it is attached to the computer.
is the programmer faulty or should i change the programming software and what should i use
http://www.ebay.com/itm/USB-asp-USB-ISP-Programmer-for-ATMEL-AVR-with-Case-Brand-New/331590922516?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D31233%26meid%3Dab5ffd784e004bec910aaf49cbdccdd1%26pid%3D100011%26rk%3D1%26rkt%3D10%26sd%3D400739546118
thanks
TucoRamirez
-Given: 257
-Receive: 115
Tuco ... dead or Alive
« Reply #1 on: July 02, 2015, 10:33:41 10:33 »
have you tried avrdudess?
micropcb
-Given: 53
-Receive: 390
« Reply #2 on: July 02, 2015, 02:20:53 14:20 »
Not sure if it will work but give a try to this.
Hope it helps.
wellnerson1
-Given: 34
-Receive: 152
« Reply #3 on: July 03, 2015, 03:06:07 03:06 »
Dear abdullahshawky,
Check whether the driver meant for the device is installed correctly? Check using the device manager? or
Use the app testlibusb-win.exe (within the libusb_0.1.12.1 folder [in the attached compressed file]) to check whether your device is connected with your PC or not?
The attachment has drivers for USBASP.
cc_chip
-Given: 134
« Reply #4 on: May 28, 2016, 06:12:08 18:12 »
Hi~
    I use usbasp and got the same problem ,too .
Finally , It working well when I add 3.6v zener diode between D+ D- and GND. good luck.
