April 22, 2025, 01:58:32 13:58
Author Topic: USB Camera on Zynq board  (Read 4978 times)
geconom
-Given: 89
« on: June 29, 2015, 07:11:52 19:11 »
I am working on a project regarding image recognition on Zynq all programmable chips, found in Zedboard and ZYBO boards. I want to integrate a cheap USB camera, but I can find no previous work to start working. I have found different solutions with a custom Avnet board, but no one with a USB camera. Does anyone have experience with such an involvement?
Elmer
« Reply #1 on: June 29, 2015, 11:44:30 23:44 »
I've used some non-USB cameras from http://www.e-consystems.com with Gumstix SOM computers, and they had fairly decent Linux drivers for their products interfacing with the image port of the Gumstix. I would expect their USB camera range to have equally good or better driver support. What is your motivation for using USB? Zynq can interface to pretty much any camera, from the expensive high resolution global shutter VITA sensors to the low cost Aptina/OmniVision sensors. If you google Zedboard+OV7670 you should find a project to get image from a cheap image sensor onto Zynq, directly without USB.
EDIT: typos
peace in the valley
geconom
-Given: 89
« Reply #2 on: July 01, 2015, 07:21:32 19:21 »
Thanks Elmer. I am trying to go with USB because they are easy to find. The OV7670 project is simple and complete but the connection is through 2 PMODS and requires some custom PCB. I am considering this solution in the future if I can not make it with USB.
