April 19, 2025, 02:15:55 14:15
Author Topic: Radio Proximity Cat Collar alarm.  (Read 4306 times)
myheadhurts
-Given: 99
« on: June 12, 2015, 08:11:50 20:11 »
Hi there folks..
My brother has a chicken coup ,that is forever being worried by his cats . (He loves cats so they stay Smiley ).
He'd like to know if its possible to mount a low power radio transmitter that will activate a collar mounted buzzer when the cat collar gets within a 20ft radius the coup.
I took a couple of transmitter / receivers I use in the 433Mhz and 856Mhz range and one of the cheap 315Mhz pairs on half voltage , and all have a far to big a radius in free air.
I also thought about using a bluetooth or zigbee type chipset that could give me a carrier signal strength detection value/threshold ,but haven't found one so far..
To Sum up .. Looking for very low power transmitter and a receiver small enough to fit a cats collar.
Any Ideas ..
TIA Rob.
towlerg
-Given: 474
-Receive: 104
What is this for?
« Reply #1 on: June 12, 2015, 09:51:31 21:51 »
Shouldn't be that hard to reduce range, you need to detune (is that the correct word), try making it shorter or longer or even attenuate it.
George
Win 7 Ult x64 SP1 on HP2570p
« Reply #2 on: June 13, 2015, 06:10:29 06:10 »
For a domesticated-cat collar, you want to use a loop antenna:
Seriously, mess up the antenna (clip it for instance, or mess up the matching network)
