February 27, 2026, 01:48:17 13:48
Author Topic: Download all files of a site using WGET  (Read 5223 times)
iot
-Given: 32
« on: April 10, 2015, 02:35:44 14:35 »
When you found a site with a lot of interesting info, links, books, you can download all the site using wget in only one command!
Here the command I use:
wget -m -p -E -k -K -np http://site
Don't forget to check the man for complete options!
Remember that it only works with direct links.
xor
-Given: 518
-Receive: 311
« Reply #1 on: April 12, 2015, 12:45:46 12:45 »
Work like a charm...tested on Windows 7 Ultimate x64... Cheesy
1. Download setup program from >here<
2. Install - default dir are c:\Program Files (x86)\GnuWin32\
3. Run wget.exe from c:\Program Files (x86)\GnuWin32\bin\, using command line with all params you need it, like iot said
This is my test:
I run in command line: wget -m -p -E -k -K -np   http://openprog.altervista.org
I found all files here: c:\Program Files (x86)\GnuWin32\bin\openprog.altervista.org\
Downloaded files new director is: openprog.altervista.org
Freelance handyman...retired after a long time illness
Cain
-Given: 170
-Receive: 102
« Reply #2 on: December 28, 2015, 01:22:39 13:22 »
Yea, wget is a great little utility that keeps you sane since it got automatic resume for broken DL's among other things.
Her is my BAT file for DL single files, caps the DL speed so I can use still use the computer...
wget.exe --continue --retry-connrefused --tries=0 --timeout=60 --limit-rate=200000 <URL to file>
« Last Edit: December 28, 2015, 01:25:30 13:25 by Cain » Logged
