February 27, 2026, 01:07:48 13:07
Author Topic: Multiple button press at a time.  (Read 11618 times)
7hills
« on: April 02, 2015, 02:35:12 14:35 »
Dear All,
I want to press two buttons at a time to do something but no luck. Pls see my code below. Im doing this due to I/O shortage. All individual codes are working perfectly except two button code.
Again:
  If PORTB.0 = 0 And  PORTB.1 = 0 Then ' this is what im trying to do but no luck.
   DelayMS 50
   Toggle LED_Green
   While PORTB.0 = 0 and PORTB.1 = 0 : Wend
   DelayMS 50
   End If
          ' below codes are working.
 If PORTB.0 = 0 Then
   DelayMS 50
  Toggle LED_Red
   While PORTB.0 = 0  : Wend
   DelayMS 50
   End If
  If PORTB.1 = 0 Then
   DelayMS 50
  Toggle LED_blue
   While PORTB.1 = 0  : Wend
   DelayMS 50
   End If
GoTo Again
-Given: 581
« Reply #1 on: April 02, 2015, 03:09:40 15:09 »
Try this because your getting locked up in the wend loop
     DelayMS 100
     Toggle LED_Green
    Wend
    End If
7hills
« Reply #2 on: April 02, 2015, 03:36:41 15:36 »
Hello.. Thanks for the reply. But still not working. instead its going to single press code and activates portb.0 and portb.1 individually. (LED blue and RED..Whichever button pressed first)
Regards.
giappolo
-Given: 1875
-Receive: 625
« Reply #3 on: April 02, 2015, 04:07:16 16:07 »
Sorry for my basic, test it
Again:
 If PORTB.0 = 0 Then
   DelayMS 200 'max delay between double key press
   If PORTB.1 = 0 Then
     DelayMS 50
     Toggle LED_Green
   Else
    DelayMS 50
    Toggle LED_Red
   EndIf
   While PORTB.0 = 0 OR PORTB.1 = 0 : Wend
   DelayMS 50
   End If
 If PORTB.1 = 0 Then
   If PORTB.0 = 0 Then
     DelayMS 50
     Toggle LED_Green
   Else
    DelayMS 50
    Toggle LED_blue
   EndIf
   DelayMS 50
   End If
GoTo Again
