March 09, 2026, 07:12:05 19:12
Author Topic: Smart (schematic) snippets ideas for design solution  (Read 8225 times)
blauwhaar
-Given: 11
« on: March 30, 2015, 02:26:49 14:26 »
I know there is Google, but why not one place to get everything you need  Wink
Sometimes you need a solution for a headache question:
For example:
keyboard decoder with ADC:
keyboard created with resister divider connection to one ADC converter,
VCC-Rf-Re-Rd-Rc-Rb-Ra-ADC-Rs-GND, buttons on Ra..f to GND.
It is possible for example 10 buttons on one microcontroller pin, otherwise
you should use a matrix which use more mcu pins.
i2c optical isolation
Think, realise and see the troubles.
solution: http://www.embedded.com/design/prototyping-and-development/4025023/Opto-electrical-isolation-of-the-I2C-Bus
i2c slave addon for debugging:
i2c slave device board connected to application to sent debug messages,
often there is no serial port available in small microcontrollers but an i2c port exists.
I use this trick for debugging small cypress usb controllers.
In future these examples must be separated, and if possible:
Smart schematic snippets
--\ ADC
    --- n keys on one ADC microcontroller pin
--\ I2C
    --- I2C optical isolation solutions
    --- debugging with I2C
I think it is very usable for developers/designers.
« Last Edit: March 30, 2015, 02:32:16 14:32 by blauwhaar » Logged
