April 22, 2026, 12:45:30 00:45
Author Topic: XC8 - MikroC / pragma udata  (Read 7911 times)
Elysion
-Given: 27
« on: March 08, 2015, 03:40:38 15:40 »
Is there any similar functionality like #pragma udata - (XC8) in mikroC? I don't want to address every register with absolute addressing.
Thanks,
Oguz
flo0319
« Reply #1 on: March 08, 2015, 04:18:32 16:18 »
I am not sure if I understood what you really want; in mikroC if you want to set an absolute address for a variable you need to use absolute directive :
short x absolute 0x22;
// Variable x will occupy 1 byte at address 0x22
int y absolute 0x23;
// Variable y will occupy 2 bytes at addresses 0x23 and 0x24
Usually you will let linker to assign addresses and align variables from optimization reasons, even more in a PIC controller where the RAM is split in banks
Elysion
-Given: 27
« Reply #2 on: March 26, 2015, 03:25:28 15:25 »
I have a lot of inline assembly in my code due to time critical issues and I don't want to change banks forward/backward due to variable locations.
So I have 40+ variables needed to be in one bank. There are structures, custom types for these variables. Calculating size/address for each to write to each absolute parameter  is very time consuming. "pragma udata" type directive is the exact needed one.
Thanks,
Oguz
h0nk
-Given: 306
-Receive: 272
« Reply #3 on: March 26, 2015, 05:36:14 17:36 »
Hello Elysion,
i am running V1.31 of XC8.
But using:
#pragma udata blub
gives:
unknown pragma "udata"
Absolute addressing in XC8 is done with "@", as in:
char c @ 0x34;
In XC8 You should also be able to put Your common variables in a psect which You can define.
I do not use MicroC anymore, so i am sorry not able to help You with Your question.
But MicroC is missing a dedicated linker, so i am afraid there are no precautions to put variables together.
But: What should this pragma doing?
Best Regards
