March 14, 2026, 06:24:59 18:24
Author Topic: MicroC, Macros, inline asm and parameters  (Read 6004 times)
Elysion
-Given: 27
« on: March 08, 2015, 12:42:18 12:42 »
I have a function like below. How could I make it compile?
MacroTest.c below
#include "MacroTest.h"
void main() {
    char var1;
    var1 = 80;
    SaveBankSelectRegister(var1);
MacroTest.h below
#ifndef __Macro
#define __Macro
#define SaveBankSelectRegister(SaveVariable)          asm { movff  BSR, SaveVariable }
#endif
Undeclared identifier '_var1' in expression MacroTest.c
Normally, if I use this as a function, I put a "_" infront of the variable in asm like below. What about using it in macros?
void SaveBankSelectRegister(char saveVariable)
   asm { movff  BSR, _saveVariable }
flo0319
« Reply #1 on: March 08, 2015, 01:51:11 13:51 »
Hi , you need to use the concatenate operator ##
#define SaveBankSelectRegister(SaveVariable)          asm { movff  BSR, _##SaveVariable }
zuisti
-Given: 242
-Receive: 780
« Reply #2 on: March 08, 2015, 09:21:54 21:21 »
This form is working:
#define SaveBankSelectRegister(SaveVariable)   asm  movff  BSR, _##SaveVariable
char var1; // global, to save BSR
void main() {
Elysion
-Given: 27
« Reply #3 on: March 25, 2015, 09:17:02 21:17 »
I have the below code. How is the correct phrase? Thanks.
source:
char  x1;
char  x2;
void main() {
    x1 = 1;
    x2 = 1;
    TestMacro(x1);
header:
#define TestMacro(sample )    _asm { movf        _##sample+1,0,1         \
                                        xorwf         _x2+1,0,1     \
Posted on: March 25, 2015, 08:50:42 20:50 - Automerged
Ok. Smiley ";" done all the magic.
