November 25, 2024, 12:47:55 00:47
Pages: 1 [2]  All
Author Topic: How to connect Ethernet Shield as client with PC, with router in between?  (Read 10081 times)
xpress_embedo
-Given: 122
-Receive: 254
« Reply #25 on: February 13, 2015, 05:03:10 05:03 »
I think you confused with DHCP Server-Client and Application Server-Client. Hope below wiki provide a little explanation
http://en.wikipedia.org/wiki/Client%E2%80%93server_model
If keep using your current architecture. Your major issue is only "How Arduino knows PC IP address is?" when PC is varying.
My suggestion is to implement Arduino in "Server" mode. Seek for Ethernet "Server" class on Arduino API, you should have a clue on what may be. Hope this help.
Yeah! i am confused little bit, initially i had to make my Arduino Ethernet Shield as Client and my PC as server, with direct connection it works fine.
But when they both are connected to router, then it PC and Ethernet Shield is working as client for Router.
I can't implement my Arduino Ethernet Shield as Server, as the project i am doing is very big and it will be a mess to setup my Arduino as server.
I just have to keep IP address of my PC as static.
bigtoy
-Given: 337
-Receive: 297
« Reply #26 on: February 16, 2015, 04:45:03 04:45 »
Yes, you can set your PC to have a static IP address. Or, some routers allow you to assign a static IP to clients, in which case your PC can remain using DHCP and the router will always give it the same address.
Just make sure the Arduino and and the PC both are within the same subnet, ie, their IP addresses are almost the same.
kreutz
-Given: 994
-Receive: 125
« Reply #27 on: February 17, 2015, 01:30:38 13:30 »
...... it will be a mess to setup my Arduino as server.
You can set both IPs as static without any problems/complications at all, also using your arduino shell as a server is just as simple as using it as a client.
kreutz
-Given: 994
-Receive: 125
« Reply #28 on: February 17, 2015, 03:04:02 15:04 »
Arduino Ethernet Shield Web Server Tutorial: http://startingelectronics.com/tutorials/arduino/ethernet-shield-web-server-tutorial/
Pages: 1 [2]  All
