April 01, 2025, 11:07:50 23:07
Author Topic: PIC Timer Calculator and Source Code Generator  (Read 10382 times)
BABYLOVE
-Given: 11
« on: December 03, 2014, 01:39:12 13:39 »
The calculators below set the Registers for PIC Timers. The Register values will appear to the right of the settings. The 'Include in Source' checkboxes determine whether that Timer will be included in the sample application code shown below the calculators. The resolution of the slider controls might not be enough to get you the value you need especially with the larger ranges. Use the sliders to get close then enter values manually. I set each bit in the Registers individually to show the code better. Most people will probably want to convert it to a single value assignment to the register. This is designed for the 16F877A, but should work with other chips that have the same registers.
http://eng-serve.com/pic/pic_timer.html
hengfeb
-Given: 45
« Reply #1 on: September 11, 2015, 02:33:35 14:33 »
I often browse this website for my programming, thanks for your offer.
« Reply #2 on: September 11, 2015, 11:32:11 23:32 »
Just FYI for more modern chips, especially newer 16F, the Microchip Code Configurator does a nice job setting up registers and values for timers and other peripherals.
LithiumOverdosE
-Given: 387
-Receive: 608
« Reply #3 on: September 12, 2015, 02:24:14 02:24 »
You can also use freeware standalone tool from ME.
http://www.mikroe.com/timer-calculator/
