November 28, 2024, 09:48:30 09:48
Author Topic: PIC Based APRS Beacon  (Read 4023 times)
germanium
-Receive: 64
« on: November 29, 2014, 09:33:07 21:33 »
This is for all you ham radio guys.  I put this together to make a simple APRS (position reporting via packet radio) beacon for flying on high altitude balloons but of course you could use it to track the location of a vehicle as well.  It's based on a PIC18F2525 and I build it using MPLAB-X and the Microchip XC8 compiler in PRO mode.  The PIC generates the AFSK audio signaling directly with a resistor network, sort of a primitive 4 bit DAC which you can hook up to an FM transmitter.
The PCB layout is done with Eagle.  I have a Trimble Copernicus GPS module on there but any GPS that outputs NMEA strings will work without modification.  The code only makes use of the $GPGGA and $GPRMC sentences.  Packets are output in the binary MIC-E format.  The code also logs the GPS NMEA strings to the onboard SD card.  I used the popular CHaN FatFS library so the card can be formatted FAT and read with a standard PC and text editor.  Have fun... :-)
charudatt
-Given: 53
-Receive: 70
« Reply #1 on: December 18, 2014, 10:37:45 22:37 »
http://www.kh-gps.de/minitnc.htm
This is the simplest one
