April 17, 2026, 11:21:29 11:21
Author Topic: Build a programmer by own 100%  (Read 10994 times)
chyelim
-Given: 813
-Receive: 134
« on: October 22, 2007, 12:24:04 12:24 »
Hi, friend, is anybody willing to share on how to build a programmer in PICs ?
My meaning is like create a own software and hardware for flashing PICs. Totally start from ZERO. Step by step up, bit by bit sending the HEX file to the MCUs.
Thanks !!
ennio
-Receive: 15
« Reply #1 on: October 22, 2007, 12:52:59 12:52 »
try PicKit2
http://www.microchip.com/pickit2
source code avaliable
I think is a good start point.
ennio
abbas1707
-Given: 15
-Receive: 25
« Reply #2 on: October 24, 2007, 02:43:05 14:43 »
hmmm
i wish to make one for 8051 Cool Cool
A Thousand Miles Journey Starts With a Single Step
phucthinhel
« Reply #3 on: November 07, 2007, 06:13:33 18:13 »
This is my programmer !  Grin It's not free !
And list support chip :
Atmel
(Hổ trợ điện áp lập trình 5v và 12v)
AT89C1051, AT89C2051, AT89C4051,AT89C51, AT89C52, AT89C55 , AT89C51-5,AT89C52-5,AT89LV51, AT89LV52, AT89LV55,AT89S51,AT89S52,AT89S53,AT89S8252,
Philips
P89C51X2BN / P89C52X2BN / P89C54X2BN / P89C58X2BN
AT24Cxxx EEPROM
AT24C01, AT24C02, AT24C04, T24C08, AT24C16, AT24C32, AT24C64, AT24C128, AT24C256, AT24C512
AT93Cxx EEPROM
AT93C46, AT93C56, AT93C66
Micrchip
24C01A, 24C02, 24C04, 24C08, 24C16, 24C32, 24C64, 24LC01, 24LC02, 24LC02B, 24LC04, 24LC04B, 24LC08, 24LC08B, 24LC16, 24LC16B, 24LC32, 24LC32A, 24LC64, 24LC128, 24LC256, 93C46B, 93C56B, 93C66B, 93LC46B, 93LC56B, 93LC66B
 Avr programmer mode parallel :
ATTiny13,ATTiny15 ( 8 pins )
AT90S1200,AT90S2313,ATTiny2313 ( 20 pins )
ATMega48,ATMega8,ATMega88 ( 28 pins ) *
ATMega8515,ATMega8535,ATMega16,ATMega32,ATMega64 (40 pins ) *
ATMega406,ATMega162,ATMega165,ATMega168,ATMega644
* : require adapter
my site :
http://phucthinhel.googlepages.com/home
« Last Edit: November 07, 2007, 06:18:08 18:18 by phucthinhel » Logged
donno
« Reply #4 on: November 08, 2007, 03:08:41 15:08 »
Build either serial or parallel programmers, both a nice and easy...a good start anyhow
http://www.foxdelta.com/products/programmer.htm
http://www.foxdelta.com/products/progserial.htm
Hope it helps!
mehdi65
« Reply #5 on: November 08, 2007, 04:37:57 16:37 »
hi
see this post
best programmers for pic
http://www.sonsivri.com/forum/index.php?topic=4394.0;topicseen
chyelim
-Given: 813
-Receive: 134
« Reply #6 on: November 09, 2007, 01:47:46 01:47 »
Hi, friends, what I mean is to build the programmer by ourselves including the software, firmware and hardware. The purpose is to learn how actually the firmware flash into the MCU. I think there is many hobbyist would like to learn about this. We need the lowest knowledge to build the programmer eg. how to send data bit by bit, byte by byte or packet by packet from computer to the flash programmer. Willem Pro and WinPIC800 is the example. Is anyone here who is expert in this ? after built then can share it open source so that other members or hobbyist will help to upgrade it become more powerful or become multi programmer that means it is not only can program PICs but also other MCUs or EEPROMs. We can call it Sonsivri - Programmer which is open source to all members and hobbyist so that we no need to source so hard for a best programmer since we have the best and expertise here in the forum. What will you think Huh  Huh
Ahmad_k
SCG Moderator
-Given: 179
-Receive: 1299
« Reply #7 on: November 09, 2007, 05:12:23 17:12 »
I'm with you Chyelim, and i think we should start understanding ICSP fonction first
ww1.microchip.com/downloads/en/DeviceDoc/30277d.pdf
« Last Edit: November 09, 2007, 05:17:59 17:17 by Ahmad_k » Logged
iphone
-Given: 115
« Reply #8 on: November 10, 2007, 11:17:55 11:17 »
I'm too ... but i just newbie. I would like very much to join the group.
chyelim
-Given: 813
-Receive: 134
« Reply #9 on: November 10, 2007, 04:04:04 16:04 »
Is anybody here can explain how actually send those bits in the HEX file from the PC to the PIC mcu ?? Can show some examples code so that begineer can get understand easier. From PICKIT2 source code is in C# language but it is too complicated and hard to understand. Can anybody shows some simple code ? maybe we can start to program EEPROM first also can.
Ahmad_k
SCG Moderator
-Given: 179
-Receive: 1299
« Reply #10 on: November 11, 2007, 06:31:40 06:31 »
The source code of PICKIT2 is divided into several functions you can see a description about each function in description file delivered with the source code. So we can you these functions  Grin Grin Grin Grin
abbas1707
-Given: 15
-Receive: 25
« Reply #11 on: November 11, 2007, 09:10:23 09:10 »
anyone interested to do it for 8051 Huh Huh lets do that......lets make our own firmware , software + hardware for 8051 programmer.
im just fed up with my programmer which is " ez downloader " available on internet.
ktl
« Reply #12 on: November 12, 2007, 12:55:17 12:55 »
http://www.willem.org
supported chip
eprom/eeprom/flash memory/pic/mcs-51/avr/.....
see download area Wink
Ahmad_k
SCG Moderator
-Given: 179
-Receive: 1299
« Reply #13 on: November 12, 2007, 06:27:51 18:27 »
Almost all new PC dosn't contain a LPT port, so this programmer isn't suitable.
chyelim
-Given: 813
-Receive: 134
« Reply #14 on: December 30, 2007, 02:48:16 14:48 »
Hi, guys, I finally found my very first PIC programmer code that had been written 3 years before which only can program PIC16F84 using LPT. Maybe this can be the starting point.
http://rapidshare.com/files/80082017/PICProg.zip
-Given: 405
-Receive: 545
« Reply #15 on: December 30, 2007, 03:30:52 15:30 »
I built this willem  and it's way to expensive and not very user freindly and I had  little joy with it to the point where I made a 16pro40 which worked 100% all the time until I  bought a Pickit2 which in my opinion is worh 3x the price they charge.you just can't beat the price and capabilities not to mention microchip support of this little gem.you will not build or dream up a programmer this good for the money they ask
supported chip
peet3kabo
« Reply #16 on: January 04, 2008, 08:46:49 20:46 »
Here's a pic programmer, maybe something for you?
http://www.picbasic.nl/galvawisp2.htm
otakis
« Reply #17 on: March 14, 2008, 11:16:23 23:16 »
hi all,
i need a starter kit and development system for Atmel's, like STK500, but cheaper.
any idea?
thanks!
